05-31-2007, 06:08 PM | #1 |
1960 Questions
I did a search and didnt find an answer so here it is: To any 60-62 owners,
1) I now our frames a diferent , how hard is it to do an under bed gas tank? I see kits for 63-up not for 60-62. 2) anyone swap there hydrulic clutch to a manual? what is needed? Yes I know stupid questions, but hey ,I need to know ! Thanks |
05-31-2007, 06:22 PM | #2 |
Re: 1960 Questions
well i dont know bout the clutch. but i have my 62 frame stripped down. i could take some pics and take some measurements and post um so you will know exactly what size tank you need.
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
05-31-2007, 07:06 PM | #3 |
Re: 1960 Questions
06-01-2007, 12:09 AM | #4 | |
Re: 1960 Questions
________________________ 62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
06-01-2007, 09:14 AM | #5 |
Re: 1960 Questions
I put a 83 Blazer tank in my 62, had to make some mounting brackets and a filler neck, and it turned out pretty good...
06-01-2007, 09:57 AM | #6 |
Re: 1960 Questions
Another thing to watchout for is if you have leaf or coil springs. I have a 65 and had to do a little mod to my aluminum tank. I replaced the crossmember in front of tank with channel iron and added one behind the tank to help prevent the Ford Pinto Flambe' syndrome.
06-01-2007, 12:07 PM | #7 |
Re: 1960 Questions
heres some pics of the frame. sorry but i havent had the time to measure. i will as soon as i can.
06-01-2007, 05:53 PM | #8 |
Re: 1960 Questions
Just curious, why do you want to get rid of the hydraulic clutch?
06-03-2007, 11:43 PM | #9 |
Re: 1960 Questions
looking to place my 61lwb 2wd on a 4x4 frame anyone know what frame would be a good fit or 60s 4x4 frame near N.C.
06-04-2007, 01:06 AM | #10 |
Re: 1960 Questions
06-04-2007, 01:26 AM | #11 |
Re: 1960 Questions
I believe the rear of the trucks are the same width and If I remeber right by the back cross brace is around 26 inches between the rails cause I planned on putting one in my 62 but got the 66 so I am doing the same thing with a fuel cell I will try to get the measurements tom for ya
http://i11.photobucket.com/albums/a1.../DSCN20132.jpg |
