Old 09-14-2002, 04:34 PM   #1
hrc200x
windshield wipers stop in the middle of the windsheild.
Anyone know the trick to fixing this problem? If I turn the wipers off they stop right in the middle of the glass, then I turn them on and their first motion is to go down. It happened after I replaced bodies on the truck. Could it be something in the motor that is bad? Thanks.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208.
hrc200x is offline   Reply With Quote
Old 09-15-2002, 12:02 AM   #2
Zkast
Zkast's Avatar
If the arm is not clocked right on the motor you could get that.
Trick:
Unbolt the arm from the motor, turn the motor on, then off again. Pull the wipers down into the normal resting position then re-attach the arm to the motor.
Zkast is offline   Reply With Quote
