06-04-2007, 12:43 AM | #1 |
Where can I get a serpentine setup?
Ive got to figure out a way to get a pulley set up for my 70 gmc. It has a 350 with heads off a pre vortec engine. The engine is new to me. Ive looked in jegs and summit and I need to find something cheaper than what they have. I plan on running a/c and it already has a water pump on it. Could i make something work out of a junk yard? The pic I have of the engine is not the best angle but the truck is 40 miles from here so this is the only one I have.
thanks for any info or ideas.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily |
06-04-2007, 01:17 AM | #2 |
Re: Where can I get a serpentine setup?
Try the local bone yards, they'll be your best bet, eBay or Craigslist next. I've seen them on eBay for $100 to $150 range before when I was thinking about it.
Here's a couple...I remember them being a little cheaper, but I don't know your budget. http://cgi.ebay.com/ebaymotors/Chevy...spagenameZWD1V http://cgi.ebay.com/ebaymotors/SERPE...14777640QQrdZ1 Mike Last edited by BigMike; 06-04-2007 at 01:23 AM. |
06-04-2007, 01:27 AM | #3 |
check out all 87-95 chevy v8 vehicles with tbi, theres hundreds of these vehicles in junk yards i used the set up off a 89 suburban for my k5 just remember when u run serpentine system the water pump spins the oppostie way as the older chevy belt engines. if ur engine is a vortec and thats the same water pump ur ok
06-04-2007, 03:34 AM | #4 |
the serpentine setup from the 4.3 tbi and vortecs bolt up fine--did the swap on a friends 85 el camino last weekend
-------------------------- '72 C10 - 350, TH350 - blown headgasket, under construction '84 K5 Blazer - 305, 700R4, Serpentine conversion, DD '97 Tahoe 2DR 4X4 - 350, 4L60E, 3.73, SPORT |
06-04-2007, 09:18 AM | #5 |
More Cowbell....
Hop in the daily driver and head down here to Jackson. Complete serp setup with pumps, compressor, etc... for about $50-75 depending on what it comes off of.
I got mine for $50.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 06-04-2007 at 09:20 AM. |
06-04-2007, 09:39 AM | #6 |
Too many projects!!!
You can get a serpentine setup of of any TBI engine from a full size car or truck form the late 80's up into the mid 90s...or a TPI engine (camaro/firebird) before the LT1...make sure you get both brackets and all the pulleys....and the fan!..don't forget the fan..it runs backwards from a normal setup...
If you go electric fans then you don't need the clutch fan...
Sean 1995 Buick Roadmaster Sedan 2004 Chevy Trailblazer 5.3L V8 1963 Chevy Biscayne 4D Sedan 1971 Chevy C10 (now have 70 cab & frame) 1968 Chevy C10 (parts for the 70) 1991 Oldsmobile Custom Cruiser (Chevy 355 motor) 1937 Pontiac 8 4D Touring Sedan (in pieces) Jacksonville, Florida Last edited by seanu; 06-04-2007 at 09:41 AM. |
06-13-2007, 02:34 AM | #7 |
Ok I got a setup off a 4.3 in a 88 s-10. Now the water pump is the question. My crank pulley looks like it is for serpentine. So Im thinkin the motor had a serpentine on it. I need to ask the guy that I bought it off of. But im confuzzed on the which works and which dont. I also have a old air a/c set up on order. Should it bolt up or will I have probs?
thanks everyone.
06-13-2007, 02:57 AM | #8 |
GEARHEAD
I say if you are in question Buy a new/rebuilt or new from the parts store to fit the application of the serp. setup. 88 s-10 4.3 in your case. They are not that much and atleast you will know then and who know the condition of the pump on there. I say it is worth it.
RJ22... |
06-13-2007, 05:10 AM | #9 |
Active Member
just make sure that the setup u get is like the one pictured above as it has the bracket already there ( pulley on the left ) for the air system to adapt to
the one pictured above has the dummy pulley in place of the ac unit mine was the same and old air sent me a adapter bracket( i think he said like a j bracket or something) to adapt there ac unit to that bracket it was slick and worked well |
06-13-2007, 10:28 AM | #10 |
Ok Im waiting on the a/c unit so Ill see soon. Thanks for the replys guys.
06-13-2007, 11:45 AM | #11 |
Can I get something like that for my 454?
06-14-2007, 01:08 PM | #12 |
for a 454, u can get one off a TBI truck from '88-'95 & the vortec engines from '96-'99....i think...
06-14-2007, 08:34 PM | #13 |
Junior Member
What's the chance I can get a serpentine belt for I6?
Keith |
06-14-2007, 08:42 PM | #14 |
Prestige member Old Farts Club
check with "inliners international" they specialize in those engines
Hey sombodys gotta do it! |
