Old 06-06-2007, 09:21 AM   #1
rckendal
Cool Wood floor
Just starting to redo my 72 jimmy. Looking to do something different. I want to put the wood in the back area like the truck beds have, is this possible and if so has any one seen this done? Thanks for any help that any one can give me with my project.
rckendal is offline   Reply With Quote
Old 06-06-2007, 09:34 AM   #2
Yukon Jack
Yukon Jack's Avatar
Re: Wood floor
Welcome to the board. There is a thread within the last month or so discussing a wood bed. Have any pics of your 72?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-06-2007, 01:33 PM   #3
Big Block
Big Block
Big Block's Avatar
Re: Wood floor
I saw one done 10 years ago and it looked good. No camera that day wish I had taken pictures. By the way It was one of the first 4 to 2 wd conversion I had ever seen. It had be lowered and when I looked up under it I saw the rear leaf springs. I asked the owner and he confirmed it. I know I'm not much help but it is possible and if done right looks great. I think he installed it on top of the metal floor.
Big Block is offline   Reply With Quote
Old 06-06-2007, 04:04 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Wood floor
There is one on here right now, but I can't think of who's it is
and From West TN
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-06-2007, 04:57 PM   #5
jaros44sr
jaros44sr's Avatar
Re: Wood floor
Welcome to the boards from Philly. Here's a couple
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-06-2007, 05:00 PM   #6
jaros44sr
jaros44sr's Avatar
Re: Wood floor
Gotta resize, that oughta take a week. J.
SAFETY FIRST
AS usual, off topic
Jim
Old 06-06-2007, 05:10 PM   #7
jaros44sr
jaros44sr's Avatar
Re: Wood floor
Here's another
SAFETY FIRST
AS usual, off topic
Jim
Old 06-07-2007, 06:39 AM   #8
jaros44sr
jaros44sr's Avatar
Re: Wood floor
and From West TN
Thanks Luv
SAFETY FIRST
AS usual, off topic
Jim
Old 06-07-2007, 08:06 AM   #9
vtblazer
vtblazer's Avatar
Re: Wood floor
Jim, can you link up your thread?
vtblazer is offline   Reply With Quote
Old 06-07-2007, 05:00 PM   #10
jaros44sr
jaros44sr's Avatar
Re: Wood floor
Maybe, if I knew what you're talking about. computor illerate
Mods alittle help here...pleaaaaaaase All I know is that it was back in May of 2006. J.
SAFETY FIRST
AS usual, off topic
Jim
Old 06-07-2007, 04:00 PM   #11
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Wood floor
Welcome from Fredericksburg,Va. What part of Va are you in?
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 06-07-2007, 05:39 PM   #12
Frizzle Fry
Frizzle Fry's Avatar
Re: Wood floor
Here you go... http://67-72chevytrucks.com/vboard/s...d.php?t=208876
...and more info would be awesome! Such as how you terminated the strips without it looking cheesy; i.e: cut ends... I want to do this in my Burb/Tahoe
Frizzle Fry is offline   Reply With Quote
Old 06-07-2007, 06:09 PM   #13
jaros44sr
jaros44sr's Avatar
Re: Wood floor
Thanks for the help Frizzle.
I think the key was the '73 and up rear cross member, because it has a 3/4" step in it and all the holes line up for the SS strips, wierd huh? Just had to notch it out to go under the tail lites, then just bolt it up like orig. and tack weld alittle.
Wheelhouses just slotted the mounting holes to the inner bedsides 3/4" and used fender washers. Also flattened out flange that usually bends under wheel arch.
Used short bed wood and cut about 3" off, had to flop sides that have the cut out for the wheel houses, needed the extra length at the rear.... still have to add little wood spacers at the step up, under SS strips, makes it look more.... finished. Take your time at the 'B' post, used a router to get the short pc. of wood to fit rite, I went a little excessive. but next time I'll get a better fit.
SS strips seem to cut best with a cut off wheel, chop saw seemed to blue up the stainless, but it would probably polish out. Cut all your wood at once, looks better on the step up. Replaced all cross pcs. w/new. Had to buy a pickup crossmember and notch it 1/2" for the forward body mount one. That's about it, but the hardest part was getting the old metal bed out,PITA. Everything sits on top like the original metal bed.
If you need specific pics. just ask. At the rate you work it will take you 15 minutes J.
Gotta try that radio fix you did...like that's not over my head, heh heh
PS, get the kit without any holes in the wood, SS strips flopped around and you could use all the orig. holes and add a few
SAFETY FIRST
AS usual, off topic
Jim
Old 06-07-2007, 06:40 PM   #14
jaros44sr
jaros44sr's Avatar
Re: Wood floor
Here's a pic. or 2
SAFETY FIRST
AS usual, off topic
Jim
Old 06-07-2007, 09:14 PM   #15
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: Wood floor
Boy I love that wood floor, that looks great!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 06-07-2007, 09:42 PM   #16
Big Block
Big Block
Big Block's Avatar
Re: Wood floor
It looks great. I think when an if I ever get to my 72 CST 2wd Blazer I'm going to do it. My bed floor will need to be repaired or it's wood. I don't think I'm going to use the rear seat anyway.
Old 06-08-2007, 12:29 AM   #17
Frizzle Fry
Re: Wood floor
Thanks for all the info and pics! Looks awesome!
Old 06-08-2007, 12:35 AM   #18
Frizzle Fry
Re: Wood floor
Here's another question for ya... What do you think about sealing up all the cracks and crevasses? In a truck bed it doesn't really matter but in a Blazer or Burb you want it as sealed as possible. I was thinking about either undercoating it or lining the bottom with peel-and-seal. Any thoughts?
Old 06-08-2007, 06:00 AM   #19
jaros44sr
jaros44sr's Avatar
Re: Wood floor
Yeah, I just used 3M 1/4" strips of dum dum, but I'll be running a catalytic converter. The SS strips are pretty tight, but you might be able to get something in the concave shape. The washers bent some, so they will have to be thicker ones used.
I plan to put a water seal on all the oak, but I don't think it will hold up. The next one will be either Trex or epay
Also to get a better fit on the strips, I plan on cutting the grooves a 1/8" deeper, they won't sit as proud on the rear crossmember
Thanks for all the compliments, you guys amaze me with your quality work that is done on your trucks
This is the area that I want to add the spacers, should seal it up better
SAFETY FIRST
AS usual, off topic
Jim
Old 06-08-2007, 07:51 AM   #20
rckendal
Cool Re: Wood floor
Chuck
I`m Near Lexington about 6 miles east of VMI. Just starting this project. I know its going to take alot of work and alot of money. Thanks to any and everyone that can give me help along the way.
Old 06-08-2007, 11:38 PM   #21
72 CustomCamper
huh ???
Re: Wood floor
Originally Posted by rckendal View Post
Chuck
You're a few miles away. I bought my first 71 Blazer across the highway from you in Buena Vista...
Chuck
Old 06-09-2007, 02:38 PM   #22
Frizzle Fry
Re: Wood floor
A lot of people don't know that the Burbs actually came with wood in the back from the factory (treated plywood). So switching to planks and strips will be pretty easy for me.
How does this apply to your Blazer? Well, the front edge of the wood (under the 2nd row seat) has an angle strip to finish off the edge. Something like this may work with the planks, but it will need slots cut for the chrome strips. That or shave the strips to fit over the angle strip.
Old 06-09-2007, 03:05 PM   #23
jaros44sr
jaros44sr's Avatar
Re: Wood floor
Kinda like your second suggestion, seems easier to shave the SS strips. Thanks for the idea, wasn't sure where to go with that area, but that will hide the end grain nicely.
On a side note, this morning I finally have my door hanging on the passenger side. Yaaahoooo, what a b!tch, fought me all the way.... J.
SAFETY FIRST
AS usual, off topic
Jim
