Got my AirBag parts Now the work begins
![]() Here is a pic of what I got. My first ? is what it heck is the big steel pipe for......? With no instructions to this stuff I only know where the bags go, the airline, and the valves.lol Anybody want to tell me where all the other stuff goes please feel free. I guess there are brackets there for a leaf spring truck that I don't need?? No too sure. Well it is a start. Going to take the bed off now and see what is next.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD Last edited by 67chevemall; 07-09-2010 at 02:26 PM. |
Straight jacket required
Re: Got my AirBag parts Now the work begins
Keep the pics coming!!!
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
Questionable
the big steel pipe is to cut in half and weld in as your c-notch
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Exactly!
The big steel pipe is prob intended for making the 'adapters' required to put the rear bags in. But on the 63-72 trucks, the rear bags will bolt-in w/o adapters or brackets. Use the pipe for whatever you need it for.....
Chimney?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Not too sure about all the parts, but most people with trucks around here put the dog in the box.
Jamie _______________________________ 72 Chevy Cheyenne 350/th350 LWB 03 Chevy Silverado Sporty Shorty 4.8L |
Questionable
meanwhile, uh, a quick search of the FAQ will help answer your other questions. please look at this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=129463
yep... the pipe is to cut and make your bag mounts for up front
#9 | |
FRONT: the "cups" in the picture are used on the bottom of the bags and the "A" shaped plate is used to mount the top of the bag to the cross member. REAR: the bags bolt in place of the OEM coils springs in the rear. no brackets needed. bolts and a few holes need drilling. my guess is the pipe is to be used for the "C" notch Last edited by Shane; 06-08-2007 at 11:29 PM. |
#10 | |
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Active Member
I am guessing c-notch, too where did you get your parts from?
'70 Chevy stepside, ECE discs & 4/6, '00 GMC ext. cab stepside, never ending project '07 GMC Crew Cab, 24's & 5/7 "We, the unwilling, led by the unquailified, have been doing the unbelievable for so long with so little, we now attempt, the impossible with nothing" |
![]() Join Date: Feb 2006
that pipe is to make adapter cups for the rear, notice the 4 flat circle template pieces to bolt up a bag too.. you cut the pipe to desired lenght and weld those on the ends
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
#13 | |
Commander Taco Bello
![]() but, that is way more pipe than anyone is ever gonna need. Also, if you're truck is a coil spring truck, you will not need to make any brackets. Just bolt the bags in place of the coils and you're set. I do also agree that you could use that pipe to make some pretty big c-notches in the frame. That saves you about $100 by not buying a bolt in kit. if you're truck is coil, you also do not need those 4 flat circle plates. The short pipe things with the flat plates welded to them, those are you cups for the front bags. All you do is bolt them to the bottom of the bag and let them "float" in the coil spring pocket. I would suggest cutting them down to 1" in height though. that will get you another 2" of drop. the 2 funny lookin plates that have a bend to them, those are you front top mounts for your bags. you just drill some holes in them and bolt them to your upper control arm. mount your bag to them first though ![]() even if you're not running a compressor and tank (don't see one in the pic) I am guessing you will need way more air line and fittings. The other thing i don't see are your gauges. even w/o a tank and compressor, you're gonna want gauges. hope that helps |
The kits are generic in nature so the amount of pipe is to make rear cups & the c-sections.
Most of the air 'kits' for these trucks do not bolt the bag directly to the frame. That's why so many of us have been moaning about drilling those freakin' large X huge holes for the air fitting & mounting bolts upside-down in cramped conditions. By making your own rear cups, they can bolt in w/one bolt on top, one bolt on bottom just like the factory coils. The air fittings are contained in the 'hat' on top of the spring. This is how I did my first air set-up. But.... I quickly realized that this method severely infringed on the amount of drop I could get. So the next go-around I bolted 'em straight in.
#15 |
I know what you meant & you know what you meant but just to clarify for those that might not know: The upper plates bolt to the upper control arm crossmember.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-09-2007 at 01:24 AM. |
#16 |
72 chevy
![]() Join Date: Jan 2007
I thought it was to make a air tank with. It looks about the right size to me.
Ed |
#17 |
looks like a pretty sweet truck and cant wait to see the instal and some pics of you playin with the bags
nice dog btw
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#18 |
Big Help Guys thanks.
Now I know that I don't need the pipe, and the 4 flat pucks, Rears bolt right in with a big hole and two small holes.(lots of drilling) Fronts: Bolt to plate, plate to crossmember, and bolt the cups to the bottom of the bag;which float in the bottom of the spring rest.
#19 |
I would be interested in seeing How Low it would go with this methed... Does this save drilling the big hole in the frame for the air line?? I don't intend on getting it into the grass, I just want the air ride and small drop. (New tires and rims level with fenders, well maybe a little under) I'll keep the pics coming for ya's Garage sale today to make room for the project. Air $500 Wheels $1800 Paint $ rob steal mob sell Motor tuneup $ won't stop detenating. ping pop pop ping. Have a good day your alive. __________________ |
#20 | |
Yes, building a 'hat' means no drilling all the holes in the bottom of the frame rail. The 'hat' only needs to be tall enough to provide clearance for the air fitting since that's the tallest thing on the top of the bag. The shorter the air fitting.... the shorter the 'hat'. Also. . ..... I originally used the Firestone bags that would be the equivalent of the 7" Slams. What I found was it had a tendency for a 'bouncy' ride @ the required air pressure I needed for my desired ride height (about 8" drop w/30psi). You may not have a problem w/the Slams since the rubber is supposed to be denser & more stable. I switched to 6" Slams so it would require slightly more air pressure which should equal a better ride (I haven't driven it since revamping the suspension).
#21 |
ttt
