06-09-2007, 08:01 PM | #1 |
cowl vent
young rodder asked me to snap some picts of the cowl and i thought i would share them with every one. ther from underneith the glove box looking up...
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
06-09-2007, 08:09 PM | #2 |
Re: cowl vent
also more picts and marc look at the last pict this is the piece im missing for both doors
gt
06-09-2007, 11:21 PM | #3 | |
Re: cowl vent
Thanks for the pics. I am screwed. The problem is the small tab with the two small bolds as seen in pic (2) of your second post. That tab swivels as you raise or lower the cowl vent. This tab was missing on my current cab so I took it off my old cab not knowing that this piece needed to pivot I welded the two tabs together. Obviously when I go to raise the cowl it binds. I guess I have (2) options. 1.) Cut the welds loose and drill out and place a small nut and bolt so that it can pivot again. 2.) weld the cowl shut. Thanks for the photos and I will look for the window channel tomorrow. Marc |
06-10-2007, 10:51 PM | #4 |
Re: cowl vent
i may have that let me check
GT
06-10-2007, 10:59 PM | #5 |
Re: cowl vent
yup i got the old vent. it's solid rust except for your tabs. they look new... how do you want them ship the whole rusty part or drill out the spot welds and send the tabs
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 Last edited by mylow53; 06-10-2007 at 11:02 PM. |
06-11-2007, 07:59 AM | #6 | |
Re: cowl vent
Your a life saver. To save on shipping I really just need the tabs from the body. My cowl vent tabs are ok. So yes, please drill out the spot welds and just send me tabs for the body. I will PM you with my shipping address. I will look for your window channels tonight as well. Let me know what I owe you or maybe we can work something out trading the channels for your tabs. Thanks Marc |
06-11-2007, 09:47 AM | #7 | |
Re: cowl vent
give me a cupple of days to get to the drilling. GT by the way the real trick for the vent to seal is to move to a dry climate...
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 Last edited by mylow53; 06-11-2007 at 09:49 AM. |
06-11-2007, 10:30 AM | #8 | |
Re: cowl vent
Take your time on the part; I have other more pressing huddles. Marc |
06-11-2007, 12:22 AM | #9 |
Re: cowl vent
I cut the drain ring out and welded my cowl up....good luck getting yalls to seal right...
06-11-2007, 08:03 AM | #10 | |
Re: cowl vent
I will have to some up with a steathy looking drain tub that goes behind the firewall. Marc |
