Old 06-11-2007, 10:44 PM   #1
72 Cheyenne402
72 Cheyenne402's Avatar
Stagger wheel size or not? 18" & 20" or 20" all the way, What do you think?
Stagger wheel size or not? 18" & 20" or 20" all the way, What do you think? This is the only thing between me and a new set of wheels. Any Ideas or oppinions are welcome.
Here is a pic to help
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 06-11-2007, 11:05 PM   #2
SCOTI
SCOTI's Avatar
Re: Stagger wheel size or not? 18" & 20" or 20" all the way, What do you think?
I did the staggered sizes because I was going to drive everyday & didn't want to worry about potholes tearing up the front rims/tires. I would prefer the same diameter wheels all the way around but it's tough to get the right size needed up front & not be too big because you're limited by manufacturers sizes.
If you can get the wheels in the right widths, 255-40/20's on 8.5's & 295-40/20's on 10's work very well & the fronts should survive common road conditions.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-12-2007, 01:27 PM   #3
72 Cheyenne402
Wat size tires are you running? It looks like I can get a 18c8 for the front and a 20x8.5 for the rear, no 20x9.5 or 10 option
Old 06-12-2007, 01:39 PM   #4
68chevy68
68chevy68's Avatar
Biggies and smalls all the way. Looks really good on these trucks. I am going to run 18 and 20's.
68chevy68 is offline   Reply With Quote
Old 06-12-2007, 02:37 PM   #5
SCOTI
SCOTI's Avatar
I have 18x8 5.25" BS w/245-45/18's up front & 20x10 5.00" BS w/295-40/20's in the back.
My fronts drag the a-arms more than I care for & on the 73-up body style you can get away w/less BS & still keep the wheel 'tucked' fairly well. IMO
5.00" front BS would work better for my 74 but I already had the wheels from another project.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-11-2007, 11:07 PM   #6
slamin69
who makes the wheels you are going to use
slamin69 is offline   Reply With Quote
Old 06-12-2007, 07:38 AM   #7
72 Cheyenne402
either centerline or Boyd
Old 06-12-2007, 02:06 PM   #8
shifty
Questionable
shifty's Avatar
i like staggered
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-12-2007, 02:44 PM   #9
itsmike2k
I have 18-8 w/4"bs front and 20 9.5 w/4.5bs on the rear on order. I have always liked the was 18's and 20's look...
Mike
1972 LT1/4l60e Short Bed
ART Front and Rear Strong Arms
http://www.67-72chevytrucks.com/vboa...50#post2151750
itsmike2k is offline   Reply With Quote
Old 06-12-2007, 03:40 PM   #10
72 Cheyenne402
What rims and size tires are you going with?
Old 06-12-2007, 04:34 PM   #11
itsmike2k
I ordered some centerlines about a month ago, new wheel and they are still building them.. Not for sure on the tire size but i'm thinking 275 40 20's and maybe a 255 45 18? Not real sure yet..
Mike
Old 06-12-2007, 04:57 PM   #12
72 Cheyenne402
Wich ones did you order? I am thinking about ordering the Voltage series. I'm not crazy about the rear backspacing though and rim size 20x8.5 withe a 5.4 BS. They donot offer these rims in a 20x9.5 or 10 unfortunately
Old 06-18-2007, 11:23 PM   #13
72 Cheyenne402
Have you recieved you rims from Centerline?
Here is the best stagger I have found matching set. Hope this helps,
245/45/18 Toyo Proxes 4 or Goodyear eagle F1
275/40/20 Toyo Proxes 4 or Goodyear Eagle F1
Results
Totals are in inches______Tire 1______Tire 2______Difference
Sidewall Height:_________4.34________4.33________.-1
Section Width:__________9.65_______10.83________1.18
Overall Diameter:________26.68______28.66________1.98
Circumference:__________83.82______90.04_______6.22
Revs per mile:__________779.61_____725.75______-53.86
Information provided by,
http://www.discounttire.com/dtcs/infoTireMath.dos
Here is a pick of both treads
Old 06-12-2007, 04:45 PM   #14
itsmike2k
Has anyonE stuffed a 315 35 20 under the rear of a 67-72 w/o mods? I think my wheel will be too narrow but a 12.5" tire is great ...
Mike
Old 06-12-2007, 05:48 PM   #15
SCOTI
SCOTI's Avatar
You would want 11 ~ 12" wheels for that tire. W/some mini-tubs & the right front wheel/tire to compliment, it would look nice.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-14-2007, 12:08 PM   #16
BigSky71
LAIDOUT
BigSky71's Avatar
I have the 315/35/20s but I widened my rear tubs to make it work, plus I am running a narrower rearend. IIRC the stock wheel tub is only 11.5" on the inside so the 315 just won't fit.
I was going to order the 295 wide but my tire guy thought we should try the 315 first. He was right. I thought I would need a wider than 10" wheel but it actually fits really well, the sidewall is vertical, not pulled back like I suspected it may be. This is a 20x10 with 3" BS.
I am running 18x8 up front with 4.5 BS and 255/45s. Sorry no side picts yet, garage is too small for that!
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 06-12-2007, 05:04 PM   #17
itsmike2k
Softtail, Yea 5.4 is a weird BS
Mike
Old 07-08-2007, 09:00 PM   #18
72 Cheyenne402
Mike,
I was checking out the centerline website and noticed the price went up on the softtails $50.00 nearly for every size wheel
Old 07-10-2007, 10:17 AM   #19
itsmike2k
Mike,
They already have my money so i think i'm locked in... They sure do run that card fast when you order ... Did you get your center caps figured out? I wonder if i'll have the same problem... I'm gonna call them today and see if they know how much longer until they are done..
Mike
Old 07-10-2007, 11:56 AM   #20
72 Cheyenne402
Yeh, It looks like I may have to turn down my rotors or find some that are at a smaller diameter so the cap will fit over them. I'm going to call a local machine shop today and see what they say.
It looks like the 5" bs on the 18x8 front wheels will work fine. but I am going to use a wheel adaptor on the rear maybe 1-1/4". The actual wheels look really nice better that expected. can't waint to mount some tires and get them on ther truck.
Old 07-17-2007, 09:56 AM   #21
72 Cheyenne402
Mike,
Have your wheels came in yet?
Old 09-05-2007, 12:19 PM   #22
BigSky71
LAIDOUT
BigSky71's Avatar
Ok, resurrecting this thread because I have some driving time on my truck now.
I am running the stagger 20 rears/18 fronts. For the look I wished I had gone with 20s on the front, but now that I am driving the truck and have found what air pressures I like, I am glad that I have 18s. I say this because even with the 18s the tires are pretty close to the inner fenders at 82-85 psi, about 2.5" I'd say. If I was running 20s with this pressure I'd be near 1.5" before bottoming out. I have driven the truck with 90-95 psi in the front and its just too rough riding for my tastes.
Of course, this would not be an issue if you don't run the stock inner fenders. If anyone would like pictures of my truck at ride height, I will be happy to shoot the appropriate picts and post them...
67 2wd Shorty
Build Pictures
Old 09-05-2007, 08:39 PM   #23
72 Cheyenne402
Mike,
Did you get your wheels from CL?
Old 06-12-2007, 05:34 PM   #24
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I plan to run 18"/20" staggered, I test fitted 20's on all 4 corners, see
pic below, but aired out I did not like the looks of the front. And I plan
to have mine drivable aired out, just in case of them oh chit situations.
That's air'd out, 2.5" spindles, tall cups, on snubbers in rear, no c-notch
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-12-2007, 05:44 PM   #25
itsmike2k
Yea i agree, i like 18 and 20's.. Just have to decide on tires now...
Mike
