Rottenwood Garage Member
I want to make a dually out of a long bed.
I need to know from what vehicle I can rob the dually rear end out of that will work under a stock long bed 67-72. I believe it needs to be narrower than a stock dually...like a gruman van or something.
Does anyone have any info on this?????????? Thanks |
#2 | |
72 C30 Trailer Queen
Re: I want to make a dually out of a long bed.
Cab/chassis trucks from 67 up to 91 (old body 73-87 style) will have rear ends that will work as far as leaf spring spacing. You will have to modify your inner wheel tubs in the bed to run a cab/chassis dually rear. One drawback to this is that you no longer have 4 feet between the tubs; something to think about if hauling sheet goods.
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts Last edited by Chris H; 06-12-2007 at 08:37 AM. |
you could something like this, he used stepside fenders and extended them down.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com Last edited by 1lowdiesel; 06-12-2007 at 08:51 AM. |
#5 | |
The LuvShack Garage
its all about the +6 inches
that's my plan too, but I want to cut it so it is narrower in front.
That is a cool truck but it needs two more doors to be just right!
Kevin LFD Inc. |
![]() Join Date: Nov 2006
i,ve got a factory dual wheel rear end, 4.10 ratio, ho 72 eaton. 300.00
bob in tn. |
Currently Blazerless
Heres a few pics of my bed, the 14 bolt rear I am using is a standard 1 ton rear so its a little wider than a cab and chassis rear. Mine uses the stepside fenders and has been tubbed, I'm in the process of changing to the larger 3 1/2" brake shoes for much better stopping power.
I may also switch to cab & chasiss hubs to tuck the tires in 2" more but I'll have to wait and see how the tires fit when its back together. ![]() ![]()
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 06-12-2007 at 06:50 PM. |
#10 | |
I would love to see a profile shot of the side of your bed, just want to get an idea of how wide your step-dually-side fenders look from the rear. Is this the one that is getting the new wheels??? That is going to look great!
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
that's sweet very clean.
what wheels you goin with?
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
The wheels are American Alloys in 19.5 x 6 and the tires are Cooper 8R C-140s
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 06-13-2007 at 07:05 PM. |
The LuvShack Garage
Epoxy Primer Friendly
The best C10 Dually ever thanks to GRANT
