Old 06-13-2007, 09:58 PM   #1
matt_field
matt_field's Avatar
wheel/tire question
hey guys, i ordered for the rear of my truck 17x9.5 torque thrust with 5x5 bs and 275/60/17 toyo proxies, am i going to run into problems?
on the american racing website they say the wheel will fit the truck. but searching someone said they rub.
Matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 06-14-2007, 01:18 AM   #2
lowdowndirtyshame67
Re: wheel/tire question
What offset are the wheels and is the truck lowered now, or will it be in the future? You need at least a standard offset and pref reversed offset to clear 9.5 inch wheels...and those tires will look great at stock or slighlty lowered ride height...
lowdowndirtyshame67 is offline   Reply With Quote
Old 06-14-2007, 06:15 AM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
based on your sig you have 3 trucks, so which one are these going on?
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-14-2007, 08:37 AM   #4
matt_field
matt_field's Avatar
the wheels are going on the 67 swb, the frame on it is a 72 frame so it has the 5x5 pattern. the truck is a fleetside. not yet lowered.. i want to get the wheels on there and lower it from there
the wheels are 7.62mm offset/backspace is 5.5
Matt
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 06-14-2007, 11:01 AM   #5
Shock_Me
Shock_Me's Avatar
If the rear end is a 72, then a 5 inch backspace works well with a 9.5" rim and a 285/60R17 tire on a fleetside truck. Not sure about the offset dimensions though. I just ordered according to the backspace.
A 5.5" backspace may be a little tight on the inner fender, but your tire is a 275 so there may be no problems for you.
Shock_Me is offline   Reply With Quote
Old 06-14-2007, 11:11 AM   #6
matt_field
matt_field's Avatar
hopefully it will work out, if not i guess a small spacer will do. thanks guys !! i really appreciate it
Matt
1967 swb 2wd 427bbc
1968 4wd shortbox
