06-15-2007, 03:20 AM | #1 |
Long Fleet Club
cleaning up the grill
is there any way that I can clean the paint off of my grill and polish it back up?
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
06-15-2007, 03:41 AM | #2 |
1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
Re: cleaning up the grill
you sure you want too? i think it looks good.
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project |
06-15-2007, 03:43 AM | #3 |
Long Fleet Club
it is a cheap paint and the whole truck is getting repainted. just trying to keep from buying a new grill.
06-15-2007, 03:50 AM | #4 |
sand it off and polish it with polish, same as you would a body panel
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME Last edited by GREASEMONKEY72; 06-15-2007 at 03:50 AM. |
06-15-2007, 03:58 AM | #5 |
Long Fleet Club
I'm wondering if a paint stripper (aircraft stripper) would work or mess up the aluminum? I'm trying to avoid sand paper because of the tight areas around the lettering and I'm lazy
06-15-2007, 06:51 AM | #6 |
Sanding it would take a year. Sandblast it and it will peel right off, no problems. I just blasted my front end. Here's before and after. This is powdercoated and I had the shop sandblast it before the powder. Only cost like $25 to blast it. Tell them to be gentle so they don't make dents. That stuff is sort of thin!
1968 C10 SWB |
06-15-2007, 06:54 AM | #7 |
brake cleaner, then lots of aluminim polish, thats what i did.
06-15-2007, 01:44 PM | #8 |
Long Fleet Club
I'm using aircraft stripper. This is my progress so for . Had to stop because it started raining.
06-15-2007, 01:59 PM | #9 |
After you applied the stripper, how did you remove the paint?
06-15-2007, 02:04 PM | #10 |
Long Fleet Club
First time was with a rag but found out a plastic putty knife worked better.
06-15-2007, 02:11 PM | #11 |
On the fast track to nowhere..
Looks like lots-o-layers.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
06-15-2007, 02:20 PM | #12 |
use paint stripper like cameeks. i would also try useing realy fine steel wool with the stripper.. you should be able to polish out what the fine steel wool dulls. i would try a little portion with the wool to see how it buffs out..
06-15-2007, 02:21 PM | #13 |
BTW, you need to mow your grass
06-15-2007, 02:54 PM | #14 |
here's another little secret for ya ... go buy yourself a roll of cheap store brand SaranWrap ... or some cheap garbage bags ... or some dry cleaner bags ... pretty much anything plastic. Anywhoo, cover a small area with stripper and then lay the plastic over the top of it. Let it sit about 10 minutes or so and then remove plastic and apply another coat of stripper. Let sit another 10 minutes or so. Remove plastic and I will almost promise that you will have a LOT more paint let go than you do by just applying the stripper out in the open and then waiting on it to "bubble up." The stripper only works when it is still "Wet" ... so by placing the plastic over the top of it, you prevent it from drying out.
Works like a champ, give it a try. Good luck. P.S. - I agree with BY88 ... the grass needs mowing. Last edited by Shane; 06-15-2007 at 02:55 PM. |
06-15-2007, 03:01 PM | #15 | |
Long Fleet Club
P.S. - The backyard is taller Saving gas money
06-15-2007, 03:10 PM | #16 |
I have some scissors you can borrow
06-17-2007, 12:11 PM | #17 | |
06-15-2007, 03:12 PM | #18 |
Long Fleet Club
I'm doing it this weekend when i'm off
06-15-2007, 03:25 PM | #19 |
A guy with a truck
8 more 1/2" bolts and that grille is off the truck. Save you from having to worry about ruining anything else with the stripper. Then you could hose it off too. Just a thought- you are literally 2 minutes from having it off the truck.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-15-2007, 03:26 PM | #20 |
Long Fleet Club
I dont want to take the bumper off again. I tryed last time and the lower piece of the grill was hitting the bumper.
06-15-2007, 04:08 PM | #21 |
A guy with a truck
It will come out with the bumper on with one of the headlights removed.
06-15-2007, 04:36 PM | #22 |
My grill was not painted, but they do have a clear anodize on these that will not let it polish if it's not removed first. I used Oven Cleaner (original not fume free) & it worked great. Just sprayed it on , let it set about 15 minutes, scrub all areas with a brush, rinse off with water hose & repeat one more time.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
06-16-2007, 05:50 AM | #23 |
Long Fleet Club
More update pics of how I'm getting along
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules Last edited by cameeks; 06-16-2007 at 05:53 AM. |
06-16-2007, 05:51 AM | #24 |
Long Fleet Club
If I keep using metal polish with the power ball will it finnaly get this stuff out?
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules Last edited by cameeks; 06-16-2007 at 05:55 AM. |
06-16-2007, 11:24 AM | #25 |
get yourself some #0000 steel wool and rub the $hit out of it ... then use the power ball.
p.s. - how'd the plastic bags work for ya? make things go faster? |
