Old 06-15-2007, 07:35 AM   #1
truckdude239
truckdude239's Avatar
flywheels and starters
okay i built m,y 305 out of an 78-79c-10 i have the flywheel out of the same truck i had it turned at school is the teeth the same as the 71 307? i just trying to figure out if i need a different starter the the ornigal one
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-15-2007, 09:43 AM   #2
69rut
Re: flywheels and starters
Use the starter off the engine you rebuilt and you should be good to go.
If you don't have that starter, check the mounting hole bolt pattern between the rebuilt block and the starter. If the bolt pattern is the same, it should work.
trailers are for boats
69rut is offline   Reply With Quote
Old 06-15-2007, 07:52 PM   #3
truckdude239
i dont have the starter off the 305 as far as mounting hole they are on the bellhouseing i am need to know about the number of teeth
David fuller
2000 Tahoe 5.3l 378
Old 06-15-2007, 07:53 PM   #4
truckdude239
just answer my own quest the 71 and 78 use the same starter
David fuller
2000 Tahoe 5.3l 378
Old 06-17-2007, 08:36 AM   #5
shootfirst
shootfirst's Avatar
If you are talking about an automatic trans There are two types of starters and two sizes of flexplates that apply during those years, 14" 168 tooth plate uses the starter that has the staggered bolt pattern and the 11.5" plate 153 tooth uses the starter with the side by side bolt pattern. Hope this helps you out?
shootfirst is offline   Reply With Quote
