06-15-2007, 07:10 PM | #1 |
Active Member
Model Number In Glove Box
For Model its CE10934.
was wonering if it was origanaly a fleetside. it has a stepside bed at this time any help would be great. BAGGER |
06-15-2007, 07:23 PM | #2 |
Re: Model Number In Glove Box
I don't think that # tells you if it was a fleet or not but it was a lwb with a bed. A flat bed (cab only) would have like a ce10904 ir somedifferent #.
72 Cheyenne Super 80 Silverado Blazer 2wd |
06-15-2007, 08:50 PM | #3 |
its all about the +6 inches
CE10934
Chassis Designation (1st digit) C 2 wheel drive Engine Deisgnation (2nd digit) E V-8 GVW Range (3rd Digit) 1 1/2 Ton Cab To Axle Dimension (4th Digit) 09 54"-59" Body 34 Fleetside Pickup |
06-15-2007, 09:03 PM | #4 |
Active Member
06-15-2007, 09:58 PM | #5 |
is it a short wheel base? (I never could remember the stupid Cab To Axle measurements)
06-16-2007, 01:08 AM | #6 |
a swb is 10734
06-16-2007, 02:06 PM | #7 |
Active Member
Thanks For the Info
the cab is from a long bed 1/2 ton i bought this truck as a parts truck they put a stepside on it . Now how do i tell if the frame is a longbed frame or short bed frame. the stepside fits on there without the frame rails sticking out of the back end. guess i need to find the vin numbers on the frame? Thanks for the Help/ info BAGGER |
06-16-2007, 08:27 PM | #8 |
I would check your # on your door pillar because when I checked my glove box it said my truck came with a stepside and the door pillar # said it came with fleetside. My truck had the fleetbed so im guessing it was originally a fleet.
70' 1/2 ton 2wd 350/muncie m-20/12-bolt rearend Darin |
06-16-2007, 09:07 PM | #9 |
the VIN won't tell you anything about what bed it came with, nor wheel base.
If the bed fits on there properly, then it's the correct wheel base. You couldn't put a SWB bed on a LWB frame, nor the other way around... without lookin REAL stupid. |
06-16-2007, 09:27 PM | #10 |
Active Member
Thanks just a little confused
I was going By the Glove Box Info W/ Base 127.0 Model CE10934. The numbers on the door match the Glove. Last edited by BAGGERSOCAL; 06-16-2007 at 09:32 PM. |
06-16-2007, 09:21 PM | #11 |
Active Member
Thanks for the Info
heres a pic of the bed on the truck the bolts are loose and the bed isnt lined up perfect The Ugly Black rear bumper is welded to the Frame . Last edited by BAGGERSOCAL; 06-16-2007 at 09:44 PM. |
06-17-2007, 11:35 AM | #12 |
Check and see if your frame has been shortened, the model number you have is for a long wheel base truck, but looks like short step. The 34 is the key to the fleet bed. Look just behind the cab for a stepped or diagonal cut and also check inside for diamond shaped plate welded to the inside of the frame rails. Hope this helps.
06-17-2007, 12:01 PM | #13 |
if there has been no cutting, then you have an unoriginal cab on the chassis.
