Old 06-15-2007, 07:17 PM   #1
19GMC63
19GMC63's Avatar
power steering conversion questions(lots of em)
Hey guys,
I've searched and searched and have found several different answers.
What work is involved in converting a 2wd truck to power steering?
I know I need to get a pre-87 box and pump/brakets and lines. (i'll make a trip to pull-a-part for that)
Once I have all that, what will I have to do?
Will the newer pitman arm work with the old centerlink?
Will I have to shorten the steering shaft? If so, how do I go about doing that?
If I can get the newer steering column with the box, should I just do that?
And do I need that adapter plate? If so, who has the cheapest one?
thanks in advance
19GMC63 is offline   Reply With Quote
Old 06-15-2007, 07:55 PM   #2
LILRED66
LILRED66's Avatar
Re: power steering conversion questions(lots of em)
I have done the conversion on several '64-'66 Chevy trucks, both two wheel drive and 4x4, as well as 1/2 ton and 3/4 ton. I have found this site very informative in teaching the basics of the conversion and I suggest you give it a try:
http://rmcavoy.freeshell.org/power_steer.html
I personally, install new steering components. I don't like the notion of installing something that has 20 plus years of use on something as important as steering. Power steering pumps and gear boxes will last that long with moderate wear & tear, however I prefer to install new, if my budget allows.
I have purchases a kit offered on eBay, to do a few of the power steering conversions. It runs around $400.00 and includes new components, including, power steering pump, engine mounting brackets, hoses, Saginaw power steering gear box, Pitman arm and steering column adapter sleeve and rag joint. For the money, buying a kit with all new equipment, is worth the investment.
Some of these kits also include the frame backing plates, for frame stiffening and gear box mounting. I don't use these kits now, because I have them custom fabricated from stainless steel and Grade 8 fasteners. They look like this:
LILRED66 is offline   Reply With Quote
Old 06-16-2007, 02:58 AM   #3
55dude
55dude's Avatar
don't happen to have a copy of the template or pattern of these do you. or maybe a pdf on computer you could e-mail a guy?
55dude is offline   Reply With Quote
Old 06-15-2007, 07:57 PM   #4
19GMC63
19GMC63's Avatar
I would love to buy new, but this tuck is a low budget build. My wallet just isn't fat enough.
thats a good idea on the custom plates. How much did it cost to get those custom fabbed?
Old 06-15-2007, 08:09 PM   #5
19GMC63
19GMC63's Avatar
Thanks for the link, a lot of usefull info.
So if I get a steering column and box off the same donor truck, I wouldn't have to shorten anything right?
Old 06-16-2007, 12:09 AM   #6
LILRED66
LILRED66's Avatar
Here is a link to a current eBay auction for the power steering conversion kit.
http://cgi.ebay.com/ebaymotors/60-66...27461304QQrdZ1
Old 06-16-2007, 12:42 AM   #7
David Flores
David Flores's Avatar
Here's another one, used.
http://cgi.ebay.com/ebaymotors/1963-...QQcmdZViewItem
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 06-16-2007, 12:58 AM   #8
19GMC63
19GMC63's Avatar
anyone know where the cheapest adapter plates can be found?
Old 06-16-2007, 05:02 AM   #9
LILRED66
LILRED66's Avatar
Sorry I don't have a copy of the template or a .pdf file. The cheapest I have seen them for is about $65.00. Maybe you can find a used kit at a swap meet or on eBay for less money.
Tony
Old 06-16-2007, 06:22 AM   #10
Woogeroo
Talking Re: power steering conversion questions(lots of em)
here is something to read up on:
Power Steering and a Tilt Wheel for the '65
rez install instructions, pg 1
rez install instructions, pg 2
Power Steering Retrofit - Make Your Classic Truck More Driveable
Adding Power Steering - 60-66 trucks
-W
p.s.
different vendors sell the REZ kits, you can call REZ and find out who might be closest to you.
REZ Engineering - No website yet, call or write - power steering kit. used trucks to part out(particularly 4x4). 1960 - 1966 Chevy/GMC. - PO Box 1584 - Great Falls, Montana 59405 - Ph. 406-727-9267
Woogeroo is offline   Reply With Quote
Old 06-19-2007, 01:15 PM   #11
steverino66
I bought an 83 donor truck for $200, grabbed the entire front end, crossmember, steering box, tilt column and all, bought a steering conversion kit from CPP on eBay, $85 shipped:
http://stores.ebay.com/Classic-Performance-Products
I haven't put it all together yet, plan to have the frontend soft parts replaced.
steverino66 is offline   Reply With Quote
