Old 06-17-2007, 10:46 AM   #1
1970shortbed
Active Member
electric fan troubles
mine have been working fine now i have issues
they are setup with a relay and they used to come on/off on all by themself now they wont come one unless i take the cover off the relay and squeeze the contacts together
the temp gauge works fine and i have a new temp sending unit and replaced the relay with a new one to no avail
these were on here when i got the truck and i dont know much about them what elses is in line to make these things work
i have replaced a couple blown fuses but still not working
any ideas and thanks in advance
ps stupid question i see people all over the forum use the words nos what does this mean
1970shortbed is offline   Reply With Quote
Old 06-17-2007, 12:49 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: electric fan troubles
Check the relay ground wire,make sure it's not corroded.
If all the connections look ok just replace the relay.
NOS=New Old Stock
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 06-17-2007, 01:02 PM   #3
1970shortbed
Active Member
NOS=New Old Stock
ok thanks
i replaced the relay already and i now rem seeing a ground wire loose not connected maybe thats it
i have a new relay for the fan on my ac evaporator and the ground wire is behind the relay to the screw that holds the relay and the fan relay has no wire
that a great idea thanks man
Old 06-17-2007, 01:05 PM   #4
cameeks
Long Fleet Club
cameeks's Avatar
New Old Stock
Parts that were made but not sold when the manufacture was making replacement parts.
I think
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 06-17-2007, 01:13 PM   #5
kbs71
71 rustless in texas
kbs71's Avatar
NOS - New Old Stock, it new parts that havent been sold by the OEM (Origional equipment manufacturer) and are usually bought up at auction by aftermarket supplier. They would be genuine OEM parts.
As for your relay, sounds like up arn't getting the control power to the relay to actuate it. When you squeeze it you make the contacts between the power wire inside. Check the wire going to Term 85 on the relay. It should have 12 volys when the relay is suppost to engerize. Term 30 should be hooked up to battery power, Term 86 should go to ground (the temp sensor) and Terminal 87 should go to your fans. Check all this out, repair any discrepancies found.
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
kbs71 is offline   Reply With Quote
