Cowboy Up
Help with 1987 3/4 ton chevy
I am getting a 1987 3/4 ton Chevy that needs a ton of work done to it. My plans are restoring it all for the most part. I guess i need help on what I should work on first? I have been told the engine and the drive train.... is that what you guys would look and fix first?
1971 chevy k10 *Under the Knife* Chris Cary ![]() |
Re: Help with 1987 3/4 ton chevy
Brakes, steering, and suspension.
Cowboy Up
Brakes, Steering, and suspension is what you would do first?
The Crazy Machanic
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
if it runs and drives desent...i'd go with these guys...brakes steering and suspension......but i would also do the major body work too before getting into the engine and transmission.....my brother is going though a truck right now and we are saving the engine and tranny for last....but they are both in pretty good shape too...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles ![]() '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L ![]() ![]() ![]() |
Cowboy Up
ok thanks for the advice, it really helps out
Drag Racer
yup id do the same chris, like i said, once we take a good look at it i will be bale to decide which way to go.
Zach Hall 1983 Chevy C10 R/T: .194 60': 2.322 330: 6.379 1/8: 9.803 MPH: 71.37 1000: 12.781 1/4: 15.314 MPH: 88.79 |
Cowboy Up
ya that would be nice but you know whats up with the truck now. It makes me upset caz we had it all planned out and everything.
#9 | |
The One And Only !!!
You will find or see better ways of doing something or more things to add and I'll bet nearly everyone on here has changed their plans also. Good Luck with your project and post some pics. when you can. ![]()
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Cowboy Up
I would but the person that i was getting the truck from now says i can't but once i find anothre CHEVY i'll let you all know.
