Old 06-21-2007, 07:51 AM   #1
Imacarguytoo
truck/car 4speed
I bought a car saginaw 4 speed last nite for my truck. It looks like i can use my 4 speed bellhousing. Are the splines in the truck 4-speed the same as the saginaw? Im hoping i dont have to buy a clutch for it.
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 06-21-2007, 07:58 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: truck/car 4speed
you may want to double check the pilot bearing size. there may be a difference. but I do believe they are both the same 10 slpine 1 1/8" input.
BTW, what is a fair price for a Saginaw 4 speed? I have a customer who is in need of one for his 74 Nova SS. he drove 200 miles with no lube in it.
68C15 is offline   Reply With Quote
Old 06-21-2007, 08:20 AM   #3
Imacarguytoo
Thanks for the help.... I have been told a price from 100-200.00
I got mine from a friend for 25.00
Old 06-21-2007, 08:29 AM   #4
larry may
Smile Re: truck/car 4speed
Put it in there it will work and fit just fine. Will have to recut the shifter hole in the floor board.
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 06-21-2007, 11:34 AM   #5
crazy longhorn
Fabricate till you "puke"
It will plug right into your 67 bell as mentioned above, but you will need to bolt & nut the bottom trans ears(the ears are threaded on the truck trans). Also, you will need to shorten & rebalance the drive shaft, & add the proper slipyolk, as the 4 spd truck trans is shorter. Best of luck, L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-22-2007, 07:28 AM   #6
You could find a 3spd driveshaft/yoke from a V8 truck,also.
