Old 06-24-2007, 08:19 PM   #1
49chevy3800
49chevy3800's Avatar
Question testing the coil
On the 49 i am trying to get the truck started after 20 years. I have rebuild the brakes, Rebuilt the water pump, So on and so forth. Now, Im not getitng spark, So i want to test the coil to make sure it is still good. I test light the pos. wire and it lights up on the frame but wont light up when touching the neg wire for the cloil. Remember that the coil is out of the truck. Is the distributor bad or am I doing this wrong. I also know im supose to ohms test the coil. How and what are my readings going to be? PLEASE HELP! thanks
49chevy3800 is offline   Reply With Quote
Old 06-25-2007, 10:39 AM   #2
71Shark
Re: testing the coil
I just started mine after sitting for 15 years. I was getting 12 volts to and through the coil and on to the dist. I replaced the coil, points and condensor for about $30 and she fired off. make sure power is getting through the ceramic block on the firewall. (check out the "she won't fire thread")
71Shark is offline   Reply With Quote
Old 06-25-2007, 11:39 AM   #3
55dude
55dude's Avatar
it is really easy to troubleshoot a points ignition system, find you a chilton's or hayne's manual and in the back of it it will tell you how to test your coil. a condenser is usually the culprit when you have no spark because when they fail they leave the system in a open state.
55dude is offline   Reply With Quote
Old 06-25-2007, 06:26 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
coil testing 101
connect the pos to battery, place tounge on the coil wire. touch the neg coil stud to ground. If your eyes roll back in your head like a shark eating a tuna its good. If you remember that you tested the coil that way its no good.
Yes I'm bored at work
Old 06-29-2007, 11:39 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a good website to help troubleshoot a points ignition.
http://abbysenior.com/mechanics/ignition.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
