06-24-2007, 09:37 PM | #1 |
wiper help please
i'm putting my truck back togather. my washer pump does not pump water. are there rebuild kits avalible ? do you get a new pump with a new wiper moter? and if i go with an aftermarket pump which wire powers the pump? is it the dark blue one? thanks a bunch
common sense isn't so common anymore |
06-25-2007, 12:36 AM | #2 |
Designated Grumpy Old Man
Re: wipper help please
I think you missed the correct forum. I will move this over to the pickup forum for you.
As far as your pump is concerned I think you still can get a complete pump or a rebuild kit thru NAPA or Carquest. Good luck oldiron forum staff
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
06-25-2007, 12:51 AM | #3 |
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
06-25-2007, 01:20 AM | #4 |
ill have to keep that in mind, mine hasnt worked since i got it
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
06-25-2007, 01:37 AM | #5 |
thanks for moving this old iron this is where i ment for it to be.i had no idea these were availible. i guess because iv'e seel so many inline in these trucks. probably because it's easier than tearing the dash apart,but mine is already apart so now is the time
06-26-2007, 06:28 AM | #6 |
Re: wiper help please
I have the same problem, but with a twist:
I bought the rebuild kit, only to find that the pump diaphragm was dry-rotted to death. The next logical step was to replace the entire pump assembly, which presented its on set of problems. First, I have a 67, which apparently has a "slightly" different design from 68-72. The pump assembly was about 1/4" longer than the original one (screw holes don't line up). Also, the original "cam" was metal, with the pump rod being nylon. The repro has nylon cam, and a metal pump rod. I can't get the metal cam to come off the wiper motor assembly, which would leave a metal-to-metal contact if I were to find a way to get the new pump to mount. The only good thing is that I'm tearing the truck down for a resto-mod. I'll probably replace the whole wiper motor assembly in the process. HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73 67 Chevelle SS Clone 454/TH400/3.73 Last edited by HomerJ; 06-26-2007 at 06:29 AM. |
