Old 06-25-2007, 06:01 PM   #1
bowtieboy93
bowtieboy93's Avatar
502
just wondering if anyone knows if a 502 with a weind 6-71 supercharger with 2 holley 650's and a 1 1/2 inch air cleaner would fit under the hood of a '69 or would i need to put in a 2 inch cowl induction hood? drop motor mounts or whatever as long as i know if it will fit or not.thx
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 06-25-2007, 06:04 PM   #2
71chevylowrider
71chevylowrider's Avatar
Re: 502
I have a very good feeling that this guy would know, bskylerj is his moniker on this site.
you should check out some of his post's on his truck, it's a big block with a super charger, well over 700HP I think now.
71chevylowrider is offline   Reply With Quote
Old 06-25-2007, 06:08 PM   #3
71chevylowrider
Re: 502
here's one of his post's, it's pretty cool stuff.
http://67-72chevytrucks.com/vboard/s...d.php?t=231627
when you click on the link above, click on the link in the first post, videos.streetfire.net
Old 06-25-2007, 06:33 PM   #4
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: 502
uuhhh.............................. no, not quite.
maybe if your hood has a 6-8" cowl.
trkklr77 is offline   Reply With Quote
Old 06-25-2007, 06:43 PM   #5
cooters
Re: 502
need more than a cowl hood!
cooters is offline   Reply With Quote
Old 06-25-2007, 06:43 PM   #6
bowtieboy93
Re: 502
i somewhat measured its like a 2 1/2 3 inch cowl the aircleaner i have now is like 6 inches tall and i had like 5 inches to the bottom of the hood
Travis
Old 06-25-2007, 06:45 PM   #7
bowtieboy93
Re: 502
i m not going with as big of a supercharger and no carb spacer plates and no scoop i have heard it can be done with some slight motor mount dropping added
Travis
Old 06-25-2007, 07:27 PM   #8
trkklr77
trkklr77's Avatar
Re: 502
uuhh thats a 6-71 super. the top plates are all about the same thickness. 1-1/8 to 1-1/2" thick.
some motor drop, you will need to gut your engine bay, fab a skiin cross and make all new mounts about 6-7 lower in the frame.
if you switch to a 144-177 weiand or b&m single carb it will fit with a small 2-3" cowl, they are only half as tall as a 6-71.
Old 06-25-2007, 08:06 PM   #9
bowtieboy93
Re: 502
oh sweet thats the best i can find on weind crappy website was that. i priced out a 502 and everything else (with supercharger) and it came out to $14,000 starting out with a ZZ502 which is 502 HP and 567 LB Ft of tq. thx
Travis
Old 06-25-2007, 08:20 PM   #10
eedgell
It's the air up here
eedgell's Avatar
Re: 502
Yah, I know a guy that put a small weind in 70 4x4, and it stuck out of the hood 3inch or so on a small block.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-25-2007, 08:28 PM   #11
bowtieboy93
Re: 502
thats not bad im gonna try and find the thinest carb that will handle the power it needs to help produce.
Travis
Old 06-25-2007, 10:23 PM   #12
69face
69face's Avatar
Re: 502
just build a 572 from a 454 and save time and money. the rotating assembly can be had for under 2 grand. just a suggestion. i like stroked big blocks. i have a stroked bbf ( 557ci ) in a 4000 lb car that runs consistent 11 sec passes. give me torque and you can have horsepower.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 06-25-2007, 08:28 PM   #13
cory321
Problem Child
cory321's Avatar
Re: 502
I think the compression on the zz502 may be too high for a supercharger.Not sure
1972 gmc sierra grande
350/350 a/c soon`to get a new 350
I Survived Norwood
cory321 is offline   Reply With Quote
Old 06-25-2007, 11:34 PM   #14
cooters
Re: 502
Edelbrock just came out with a small blower, looks good. As far as lowering the motor, my big block is only 1/2 inch from the x member now and major cutting would be needed to drop it more than 1 inch
Old 06-26-2007, 02:24 AM   #15
bowtieboy93
Re: 502
i went to edelbrocks site and no success i didnt find a thing on prices on them and it didnt say applications and it was only from stock motors. it said "will give u up to 500 hp and 557 lb ft of tq which the motor im starting with already has more than that
Travis
Old 06-26-2007, 09:45 AM   #16
cooters
Re: 502
You have a problem, to make boost on a 502 without excesive intake air temp requires a bigger blower than a 6 71 but you dont want it sticking up. You will not get the best of both worlds. I believe that what you are trying to do is not realistic.
Old 06-26-2007, 02:56 PM   #17
bowtieboy93
Re: 502
i have seen a blown 502 done with a weiand blower i know for sure it waasnt bigger than a 6-71 and that car ran low 11's
Travis
Old 06-26-2007, 10:32 PM   #18
cooters
Re: 502
a stock 502/502 should run in the 11s without a blower if the car doesnt weigh 4500 lbs. You need to figure out what your goal is for the motor and then come up with a combo that works. Spinning a little blower to make 5 lbs of boost on a 502 will heat the air up alot and detonation and general undrivability on the street will occur.
