06-25-2007, 09:44 PM | #1 |
Need shifter info
I bought a 69 c10 that the prior owner installed a Hurst Mastershift conversion in. It converts the three-on-the-tree to floor shift.
I need to see if anyone has the installation instructions for this kit because this thing seems to be really screwed up. I am having dificulties finding any gear. (and yes I know how to drive stick) I also thought it was odd to have this shift pattern: R 2 1 3 I guess this is the only way to set it up??? Any help would be appreciated. |
06-25-2007, 10:04 PM | #2 |
Re: Need shifter info
That's the normal shift pattern for a 3-speed.
06-25-2007, 10:10 PM | #3 |
its all about the +6 inches
I've only driven a few vehicles with that shifter, but they all shifted like crap.
06-25-2007, 10:11 PM | #4 |
mines been converted and it goes
1 3 R 2 It shifts just fine
71 chevy longhorn 1 ton 79 chevy straight 6 79 burb 454 91 silverado 350 TBI and a few others that my brand loyalty wont permit me to post. Eureka Boys!!!! |
06-25-2007, 10:37 PM | #5 |
I've never seen a 3 speed with that shift pattern in my life.
06-26-2007, 07:09 PM | #6 |
Active Member
Did you adjust the shifter? There should be a small (about 3/16) hole in the side if the shifter that also goes through the 2 levers on the shifter. Disconnect both rods from the levers on the shifter, make sure the tranny is in neutral and put a rod or driil bit through the hole and levers on the shifter. Now aduust each rod so it slips easily into its lever on the shifter. Hope this helps the problem.
69 C10 LWB Project 47 Cushman Scooter Project It is better to have loved and lost than to live with a psycho all your life. |
06-26-2007, 08:37 PM | #7 |
I am a Referee of life.
chevroletman,the reason it shifts that pattern is due to the shift arms on the tranny being turned 180*.I had a buddy in HS who did his that way so his GF could have leg room when she sat next to him.It was in a 60 Furd with a 390.Right after he installed the shifter the rearend went out.The local Furd dealer(small town of 1200) replaced it with a rear from an auto.Sure crused the hiways easy but was he&& on clutches.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-26-2007, 08:38 PM | #8 |
I had a Hurst Indy Shifter in my truck when it was a 6 w/3 speed. Shifted great. One thing that happened on mine that made it loose was the bolts holding the shifter onto the linkage came loose (I didn't use lock tight first time).
3 speed pattern R 2 1 3 If the shifter rods are hooked up wrong you will get the second displayed pattern, but I won't tell you why I know this 1 3 R 2 I am not sure what the difference is between the Indy and Mastershift models, but I do know someone who used a Mr Gasket version of the shifter, and it was pretty sloppy, but may just have need the rods adjusted too.
