Need some help
Does anyone have a part number or know where I can buy an E-Brake light switch??
Thanks,
Alan |
Re: Need some help
TTT one time. I'm really needing one of these.
Alan |
Re: Need some help
Are you referring to the switch that activates your break lights or is there actually a light switch for turning on a light when the e-brake is on???? Never heard of or seen one in a 67-72 pickup.....
Am I about to learn something again today????
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
Re: Need some help
There is a switch that activates a dash light that lets you know that the ebrake is on.
Alan |
Re: Need some help
If I'm not mistaken they are fairly universial pin switches.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
Re: Need some help
Sorry, worked on too many Mopars... ![]()
Re: Need some help
Were is the switch located?
I notice when I start my truck I have a dash light thats says brake, but it does not activate with my park brake.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
Re: Need some help
no ebrake indicator light on 67-72chevy trucks
Re: Need some help
[QUOTE][no ebrake indicator light on 67-72chevy trucks/QUOTE]
Are you sure? I have a harness connection for one but can't swear that there was a switch when we tore it apart. If you are sure I'll just cut the wires back tape them off and hide them under the dash. You know mine is a GMC don't know if that makes a differance.
Alan |
#10 | |
Re: Need some help
[QUOTE=hambone1958;2240602]
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Re: Need some help
I'd have to go look to see what color they are......but I told my mechanic to go ahead and get rid of them and I'm sure he has done it already.
Alan |
Re: Need some help
These trucks did not have a switch that lit when e-brake was on. The light on dash is lit when front or rear brakes fail. It works off the prop. valve (tan wire). I made my own using a brake light switch and a L-shaped bracket mounted on e-brake bracket so that the switch button would release when brake was pushed on. Ground one side of the switch and tie the other wire to the tan wire fron prop. valve. This will light the brake light on dash when your e-brake is on.
#13 | |
Re: Need some help
