Proper location of temp sender?
'72 Chev 350. I have my temp sender in the intake manifold at the moment. Does it need to be in the head? The gauge is working but goes all the way to hot after a couple minutes of running and driving, but the engine isn't that hot I don't think and the radiator cap doesn't open and overflow...
1972 C10 1972 C20 ![]() |
Re: Proper location of temp sender?
All my original trucks had them in the driverside head.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
GEARHEAD
Well as OLDCHEV4X4 stated in the head is the stock location on most applications.
As for you I would say there is something amiss some where. As the head will/should give you a higher reading not lower, as this is where all the action is going on. BTW Buy a new cap. RJ22... ![]() |
Okay I will try a new radiator cap... maybe hook up a mechanical temp gauge.
