how much to cut?
can someone tell me how much I need to cut off a stock set of front springs to get 3".I know if you cut 1 coil it will drop it 2" but how much for 3".it's on a 1970 1/2 ton.thanks
Dave's not here, man
Re: how much to cut?
I cut 1.5 coils and got about 3.5" However, I wouldn't recommend doing this. The truck rode like crap, and you could hear the spring bouncing around in the pocket when you went over bumps.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
The rule of thumb is cutting 1 coil = 2" drop but not all springs are equal. You might get 2" on one truck & 3" on another.
Cut 1 coil & put them back in to see how much drop you get.
67-72 Addict!
1 and a quarter coils cut off will give 3" of drop.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
i dont suggest doin that just buy 3'' drops
alot less hassle |
I just want to do this to get me bye until I can get bag's.it's not a daily driver.thanks for the input
#7 | |
Warning: Some trucks have issues w/running out of threads on the upper a-arm studs when cutting off enough coil to get 3" or more of drop. You might have to get new, longer studs if you go this route.
#8 | |
F.A.S.T. president
![]() Join Date: Sep 2003
I have 3 " springs and I ran out of threads to get my caster adjustment like he said. I bought longer studs and made 1/2 spacers, so I dont have such a large shim stack.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 07-04-2007 at 09:10 PM. |
thanks guy's.I have 1 coil cut right now and I'm just waiting for some cooler weather to put them in.
if you go with aftermarket coils will you still run out of threads?any pics of the bolts you need to change?i was planning on cutting 1.5 to 2 coils when i swap on the disc setup.
#11 | |
The exceptions to this rule are adjustable a-arms or re-designed (shortened lower/stretched upper) a-arms.
