Old 06-28-2007, 05:42 PM   #1
cochino12
It followed me home?
cochino12's Avatar
Help me pick a cam
Ok so I'm swapping the 350 in my 2wd K5 for the 454 from the other truck I just bought next weekend and I figured I'd at least put a cam in the 454 and 350 while I had them out.
the 454 will be in used in the 2wd blazer thats mainly used on the weekends and I'd like to get as much out of the motor (stock) as I can and still have the power brakes etc... work well.
The 350 will be in my 3/4 ton 4wd that will pull a small trailer and maybe used for plowing snow
I know next to nothing about this stuff so I figured I'd ask the experts here, thanks in advance for any input
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 06-28-2007, 06:35 PM   #2
benoit454
Chris
benoit454's Avatar
Re: Help me pick a cam
I run a comp 268h in my monte carlo and they said it's good for basically stock motor as far as cabr, intake, headers and convertor goes, but it has a nice lopey idle and good performance too. I like it.
However I should have went bigger like the magnum 270 or the next one up since they say aftermarket carb, intake, headers, and converot r which I have all of the above now.
Some of the small block cam shafts said rough idle in small blocks and noticeable lope in big blocks. So I think the 268 would be a great all around cam for either one, especially if you'd like to have that camm'd up sound in them.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 06-28-2007, 06:51 PM   #3
ChaseDale3and8
ChaseDale3and8's Avatar
I have run the 280 Magnum cam that you are talking about. It is an awesome camshaft! You have to build that motor up a little bit to take full advantage of the cam's potential though. It has a long duration and quite a bit of overlap hence the very rough idle that it has.
You either need a stall converter or a manual trans with that one because it idles between 850-900 r.p.m. and it has a very rough aggressive idle at that. It is a very bad ass sounding cam and I liked the one that I used to have in my 82 when I had it years ago. My engine was built around that particular cam though (higher compression pistons and ported and polished heads). For a stocker a 268 would be a much better choice, but I wouldn't go past a 270 at most. Just my honest opinion. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 06-28-2007, 06:36 PM   #4
jchav62
1962 C-10
jchav62's Avatar
For the 350, go with an RV cam since you are planning on pushing and pulling with it. This will give you the low end torque you will need.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-28-2007, 06:40 PM   #5
ChaseDale3and8
Everyone has their own preference as far as brands and grinds that they use. Mine is Competition Cams 268 High Energy. It has a good idle works well with power brakes and A/C.
It is a good cam for a pretty much stock engine and will give you a strong bottom end and midrange which is what you need in a truck. It is easy to overcam an engine and hurt it's performance rather than help it. You want to avoid the long duration cams with a lot of overlap in an otherwise stock engine.
This particular grind is perfect for a truck with a pretty much stock engine. Headers, a dual plane intake manifold such as an Edelbrock Performer, and the right carb will wake up a stock engine. Just my preference. ...Joe
Old 06-28-2007, 06:46 PM   #6
Dragster66ss
Dragster66ss's Avatar
Agree with any version of the 268. Its the only thing my dad will put in a street use motor, almost invariably on the application.
IMO its the perfect cam for the street: enough that Everyone knows it is def not stock, and not too much that it sacrifices vaccuum. Win/Win if you ask me.
$.02
Lee Roberson
'77 Sierra Classic 454/th400
Other toys (Non P/U's):
67 Chevelle 427/m22 (My street ride)
3 1966 chevy II drag cars (fam racing operation: pop, lil-brother, and myself)
Dragster66ss is offline   Reply With Quote
Old 06-28-2007, 07:04 PM   #7
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
http://store.summitracing.com/partde...2&autoview=sku
this the 268 high energy cam?
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 06-28-2007, 07:21 PM   #8
ChaseDale3and8
Yes. That's the one. ...Joe
Old 06-28-2007, 07:35 PM   #9
cochino12
cochino12's Avatar
great, thanks for the info guys
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 06-28-2007, 10:06 PM   #10
benoit454
Chris
benoit454's Avatar
Yea that's the same one I got I bought the cam and lifter set for $168 but after about a year one lifter started ticking, and I heard from alot of people comp had a bad run the last year or two ago with bad lifters. I changed them out for a pretty much stock replacement set and they've laster about a year now without ticking any at all.
Chris
GIT R DONE!!!!!!
Old 06-29-2007, 01:04 AM   #11
cochino12
cochino12's Avatar
Any opinions on this? Desktop dyno show a pretty good increase and can still use it on stock components
http://www.holley.com/00020.asp
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 06-29-2007, 11:09 AM   #12
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Are we picking for the Blazer 454 or the pickup 350 or both?
350 = 268 advertised with around 450 lift is good for a mild motor. I love the competition 268, if you are more into pulling, you may want to drop down to around 260 advertised (RV cam)
454 = 280 advertised with around 520 lift is good for a stock 454.
A 268 in a 454 is going to be REALLY mild. The Lunati you listed looks pretty good.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-29-2007, 01:36 PM   #13
cochino12
cochino12's Avatar
Both, I figure I'd wake them up a bit while I had them out. I'm leaning toward the lunati, the numbers look pretty good to me.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
