Old 06-30-2007, 12:52 AM   #1
cell
Active Member
cell's Avatar
is there such a thing as a brake drum puller?
I am gettin tired of beating the @$^(% of my brake drum rotors in order to get them to come loose. I can't seem to find anything resembling a brake drum puller online, but I figure it should be pretty easy to fabricate my own tool. I could start with a 3 jaw puller from harbor freight and just make new arms for it which will fit around an 11" brake drum.
cell is offline   Reply With Quote
Old 06-30-2007, 01:02 AM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
Re: is there such a thing as a brake drum puller?
I have disc at all four corners, so I don't know if this is true for our trucks, but do the drums have two threaded holes on the face? I seem to recall that you could put a bolt in those holes and as you tighten it, it would push against the axel and force the drum off.....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 06-30-2007, 01:21 AM   #3
dave2953
Dave's not here, man
dave2953's Avatar
Have you tried adjusting the shoes inward? This should allow the drums to be removed easily. If they are on that tight chances are good that something is wrong.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-30-2007, 01:34 AM   #4
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
a big enough jaw puller will work.
trkklr77 is offline   Reply With Quote
Old 06-30-2007, 01:21 AM   #5
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Yeah, they make em. You could borrow mine if you were closer. I googled it and found these:
http://www.google.com/search?q=brake...e7&rlz=1I7GWYA
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 06-30-2007, 01:49 AM   #6
lbpd719
Zappaphile!
lbpd719's Avatar
I once had a buddy that was restoring a mini in his garage.
it stood on jackstands for 4 years and he went through about 20 brake drums looking for ones that fit correctly. He could never get a set that would fit.
One day I went over for a couple of beers to BS with him, and he told me about the situation with the drums and showed me a few of the sets he had aquired over the years.
I looked at the brakes, reached inside the car, released the parking brake and bang, drums he had all fit..
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 06-30-2007, 07:11 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
thats freakin great
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-30-2007, 10:56 AM   #8
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 06-30-2007, 04:54 AM   #9
gator2511
gator2511's Avatar
I rented a big jaw puller to get my drum off. One came off easy and the other was NOT coming off. The shoes were backed off too. When it broke loose it sounded like a rifle shot. Never had to do that before but if it happens again I'll rent the puller again, about $12.
gator2511 is offline   Reply With Quote
Old 06-30-2007, 06:57 AM   #10
cdowns
cdowns's Avatar
front brakes rear brakes?? if its the front drum brakes you do know that you take the hub and wheel bearings off for the brake drum to come off you do that by removing the grease cover than the cotter pin then the cast;e nut // old school way do brakes and grease front wheel bearings at the same time
Old 07-02-2007, 10:41 AM   #11
cell
Active Member
cell's Avatar
Are you sure about all that? I just need to remove the drum itself. You have to pull the wheel bearings just to get the drum off?
Old 07-02-2007, 10:02 PM   #12
71tahoe
71tahoe's Avatar
I agree. The easiest way to take the front drums off is the same as a front rotor. Remove cotter pin, castle nut and washer.
I beat on a rear drum for about 20 minutes and didn't budge it. The adjuster was frozen so I couldn't loosen it. I got a mapp gas torch and GENTLY and EVENLY heated the drum face. It expanded just enough to allow me to tap it gently with a hammer and start sliding it off. I had to reapply heat a couple of times but it came off much easier. Use gloves!!
71tahoe is offline   Reply With Quote
Old 06-30-2007, 10:52 AM   #13
SacramentoJoe
Always Fixing Things
SacramentoJoe's Avatar
"I looked at the brakes, reached inside the car, released the parking brake and bang, drums he had all fit.."
LOL, that sound like something I would do!
Just an Average Joe
‘68 GMC 307 3spd – My dad's original truck
310,000 miles
SacramentoJoe is offline   Reply With Quote
