Sorry it took so long, I was knee deep in a boat project, those photos are also on my webshot site if you care
.To the seats, I had to lop off a portion of the seat frame. These are in 2 pieces (60/40 split) I cut the rear corner of each end so the seat could rest on the lifted rear of the burb. I also had to remove the spring loaded carpet pieces on the rear they were just in the way. I then mounted the front 4 blots and 2 in the bar that remained from cutting off the corner. I then put a bot though the upper bar though the little lift wall in the burb(that is a thick piece of steel
That was it, ended up with 4 bolts in each part of the 60/40 so a total of 8 bolts. Oh I also reinforced under the truck where the bolts go through, that should always be done, safety safety.
Well enjoy the photos. Just click on the photo to see more.
