Old 07-04-2007, 01:40 PM   #1
CG
BlahBlahBlah
4 3/4 lug pattern...can we?
Is there a way to run these on our trucks? Anybody make front rotors drilled to that pattern that will swap out with our current 5 on 5's ? Does anyone make rear axels drilled with that pattern we can swap out our six or five lug axels with?
Old 07-04-2007, 02:56 PM   #2
cdowns
cdowns's Avatar
Re: 4 3/4 lug pattern...can we?
there are wheel adaptorsa out there for changing bolt patterns they usually add about 1 inch of width per wheel// i see them on ebay some times
Old 07-04-2007, 08:36 PM   #3
CG
BlahBlahBlah
That extra inch can really mess you up if you're lowering your ride.
Old 07-04-2007, 08:52 PM   #4
SCOTI
SCOTI's Avatar
Most machine shops can redrill the 5x5 to 5x4.75 bolt pattern on your axles & rotors.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-04-2007, 09:15 PM   #5
Lil-Joe
Lil-Joe's Avatar
...Yea, I'm in the same boat....I was given aprox. $1500.00 worth of Rims & Tires for my truck, 29x18.5x15 Mickeys on 15x14 rims (5 on 4.5" b.p.) for the rear, set up for a 9" rear and 27x7x15 M.T.'s (5 on 4.75" b.p.) for the front ......my thing is ...Being some rims are "Hub-Centric", and others are "Lug-Centric"....will a machine shop turn down the hub size if needed?
1969 chevy C-20 (soon to be shortened & Tubbed C-10)
1990 Astro AWD 3" Lift w/Laredo tires 10 spkr. 800w system and DVD player for the long trips (got it for free) and been trying very hard to "De Socker-Mom it !
Lil-Joe is offline   Reply With Quote
Old 07-04-2007, 09:18 PM   #6
SCOTI
SCOTI's Avatar
Yes, if they're set up for drilling rotors/hubs, they can turn the hub down as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-04-2007, 11:17 PM   #7
Shane
Shane's Avatar
actually the turning of the hub will require a lathe and the re-drilling of the bolt pattern will more than likely be done on a knee mill ... two different setups. but any competent machine shop will have both pieces of equipment needed to do this for ya.
Shane is offline   Reply With Quote
Old 07-05-2007, 12:05 AM   #8
CG
BlahBlahBlah
Well I had a line on a set of wheels that were a very good price. But it sounds like the cost to make a truck work with these is going to be to prohibitive. Thanks for the responses guys.
Old 07-05-2007, 01:03 AM   #9
67 cst swb
67 cst swb's Avatar
Also,you can...
find a 71-72 or 73-74 Chevy van... YES Chevy VAN... they had 5 on 4-3/4 bp from the factory. Only 71-74. 75 they went to the 5 on 5. (This is what kind of info 20 years in Auto Parts gets you) All you need is the spindle. ball joints and tie rod ends are the same as pick-up. for which ever year respectively. 71-72 same as 71-72, or 73-74 uses 73-later stuff...
here's the cool part. the caliper, rotor and pads are 70-77 camaro, so easy to find replacements parts for. Also, some aftermarket companies even sell slotted performance rotors and replacement dual piston calipers for 70-77 camaro...
Here's the only possible negatives... FIRST, finding a donor 71-74 Chevy Van... Second, the rotor diameter is a bit smaller, thickness is the same. So your unfortunately not going to a larger diameter rotor, but a smaller... I'm not sure but our trucks are 11" (?) and these Van (camaro) are 10-1/2" (?) you might want to double check that...
But, I luckily have 2 pairs of these spindles. one set is 71-72, other is 73-74 I will be using one or the other on either this current project or the next project. All this just to run corvette style rally's.
Any quality machine shop can redrill your rear axles to 5 on 4-3/4 bp, then just go buy rear drums for the 71-72 chevy van, the shoes and hardware is all the same as our pick-ups
PM me with any questions...
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 07-05-2007, 09:44 AM   #10
CG
BlahBlahBlah
Hey thanks for that very good info. Im going to have to save that. Late last nite someone offered the guy more money for the wheels than I did. Now I have to decide if I want to up the anti (sp?).
Old 07-05-2007, 03:18 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
That is interesting info on the van spindles, but I think it is going the wrong direction for better brakes and lowering our trucks.
You have to get rare spindles. They do not lower the truck...and it takes expensive aftermarket HP brakes to make it stop. A set of 5on5 wheels are looking better to me. Just mho.
PICKMUP is offline   Reply With Quote
Old 07-05-2007, 03:36 PM   #12
67 cst swb
67 cst swb's Avatar
I do agree...
the truck I'm using mine on will be a weekend cruiser, no load, stock engine, so I guess my thoughts were the camaro disc will still be better than the '67-'68 factory drum brakes, I'm taking off.
I did list the brake size as a negative...
My Trucks:
