Cereal Killer
72 Blazer Doors
Looks like at least my driver side door is pretty bad off........may repair if I can find a couple of good corners to splice in but looking to replace them at this time. I have a set of pretty cherry 67 truck doors I can use. Whats yalls opinion on this dilema? I also have the steel door panels for th 67 doors that are in pretty good shape....no arm rest holes.
If I dont do it....somebody else will. |
![]() Join Date: Jun 2002
Re: 72 Blazer Doors
Personally, I had rather have good doors than correct doors.
jmho, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
SKINNY TIRES RULE!
Re: 72 Blazer Doors
Save yourself the effort of repairing the rust and cut the 67 doors down. You can use the reinforcing plates and those weird little gizmos at the top of the blazer doors to make them just like the stock doors.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Cereal Killer
Re: 72 Blazer Doors
I had the 67 doors saved for this reason....hate to screw up this resto ...I guess one piece windows would look cool in the 67 doors too. Exactly what reinforcement plates do the k5 doors have that the truck doors dont?
The LuvShack Garage
Re: 72 Blazer Doors
GQ has truck doors on it
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Re: 72 Blazer Doors
The blazer doors have a plate around the latching mechanism on the back edge of the door. I may have a pic somewhere...
Cereal Killer
Re: 72 Blazer Doors
Thats what I was thinking about the plat by the latch.....just making sure there wasnt anything else special about them.
Thanks for the info
Re: 72 Blazer Doors
Well, there is a screw under the vent window too, I have it on my 70 Jimmy but not on my 69 blazer. I think it may even be on regular trucks. I didn't have any luck finding a pic of the latch plate.
Rg
![]() Join Date: Jan 2007
Re: 72 Blazer Doors
The screw under the vent window was a 72 only door feature. It held the door skins together (as they were prone to separating there due to rough vent window use).
You may have a 72 door in your 70... I have one of each in my Blazer- Driver = non-72 Passenger = 72 |
SKINNY TIRES RULE!
Re: 72 Blazer Doors
Really? I don't remember that. I remember a small screw with a black bezel on one of the doors, but that isn't what the 72 doors look like. The screw is recessed into the door, at least that is what is on my 72.
Re: 72 Blazer Doors
Bouncy - you are correct - I think I have the afterthought mod of the black plastic piece and the screw (instead of the dimpled door with a screw).
Pix for all to see. |
Re: 72 Blazer Doors
Can you guys be more specific to the differences in the Blazer and truck doors or is there more specific info somewhere else?
I just realized today that both doors on my '71 have quite a bit of rust, top to bottom in the hinge area and the door bottoms. ![]() I was thinking that a truck door could be modified but wasn't sure if it was possible. Thanks
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
#13 | |
Re: 72 Blazer Doors
The second picture is a stock Jimmy door. They came that way from the factory 70-72. I can't speak for the blazers but I'm positive about the jimmys. We have posted about these doors before, I'll try to find it... Here are a few. Looks like these were on Blazers too... http://67-72chevytrucks.com/vboard/s...ht=door+screws http://67-72chevytrucks.com/vboard/s...ht=door+screws http://67-72chevytrucks.com/vboard/s...ht=door+screws Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Last edited by raggedjim; 07-10-2007 at 05:11 PM. Reason: New info |
Re: 72 Blazer Doors
Here's a picture of how the screw is held and the metal support. I guess the screw doesn't help much, see the cracks?
Rg
#15 |
Re: 72 Blazer Doors
All Blazers and Jimmy's doors are originally truck doors that the factory cut down and modified for use on the K5's. They cut the tops, then added a "reinforcement plate" around the door latch mechanism (spot welded in place). They also added a small brass shim to the door and the B piller to help hold things in alignmnet. Most Blazers and Jimmy's I've seen back to 1970 had the addition of the tie-in screw below the inner side of the vent window to try to hold the inner and outer panels tighter together. That "tie-in" became standard on trucks in 72.
First year production is always a little different as the plants work out cheaper, quicker ways for manufacturing. The 67 trucks are very unique as are the 69 Blazers~~~not more valuable, better or worse---just a wee bit different then later models. ---Huck |
