07-08-2007, 02:41 PM | #1 |
It'd be alot cooler if you did
new carpet?
Ok, first off, I've read some bad things about ACC carpet. What brand should I get, and where?
The other thing is this... I have the high trans hump, and my shifter is not in the stock location because I have a muncie and not a saginaw. Am I going to be able to get a high hump molded carpet kit with no holes in it? |
07-08-2007, 04:05 PM | #2 |
No No
Re: new carpet?
I got my carpet from GMC Paul's which is a site sponser. You can get the tall hump from them it's not an issue but your going to have to cut a hole for your shifter since the carpet has no holes in it whne shipped. Just make sure to double check the color. I wasent to happy with the color I got it dident quite match the picture.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
07-08-2007, 06:14 PM | #3 |
Re: new carpet?
yeah, I want to cut the holes in it myself because it wont be in the factory location.
so.... will I need to order it for a k10 to get the high hump mold? |
07-08-2007, 09:08 PM | #4 |
Chris
Re: new carpet?
No any manual trans factory truck or 4x4 had the high hump.
The autos on column and 2wd's had low hump. I'd just tell them year make model and high hump.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
07-09-2007, 03:58 PM | #5 |
www.73-87chevytrucks.com
Re: new carpet?
I haven't had any problems with ACC which is why i sell them, but to answer your question, you just need to order a 2WD high hump carpet kit. They did exist.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
07-09-2007, 04:27 PM | #6 |
Garage Queen Material
Re: new carpet?
i just installed a carpet kit from chevyduty and i really like the quality.
07-13-2007, 01:35 AM | #7 |
Re: new carpet?
how about 2 wheel drives with factory 3 on the tree, low or high hump? thanks bob
07-13-2007, 01:49 AM | #8 | |
Re: new carpet?
If you post a pic, I can tell you what it is.
