drag it like you stole it
the gap between the door and the cab (not door and roof) seems to be alot larger than the gap of the bootom half of the door. i think i know the reason, but i would like some input. the lip partion of the drip rail that hooks to the door jamb would probably fill that gap some but it was taken out with the drip rails. i hope this makes since. thanks. oh yeah.. the question is how could i shrink this gap..tack a strip of sheetmetal in?
negative camber //LA\\ |
If you need to fill in gaps between the door edge & cab sheet metal weld strips of metal or welding rod as a filler.
