07-11-2007, 06:11 PM | #1 |
Picked up my 73-87 crossmember, what now?
What will be the easiest to do.
1. Leave the current crossmember in and swap the arms and steering. 2. Pull old crossmember and install the new one? I want to do which ever is quickest. What are the advantages of swapping the crossmembers or just parts? Thanks |
07-11-2007, 06:22 PM | #2 |
Too Many Clubs Club
Re: Picked up my 73-87 crossmember, what now?
I say leave the current crossmember in and swap everything out. That way you can replace all the worn bushings, rod ends, ball joints, etc. and have everything under the front of the truck fresh and new.
How I installed my air bags... |
07-11-2007, 06:46 PM | #3 |
If any of the new parts are questionable, replace them. |
07-11-2007, 07:21 PM | #4 |
It's more work to swap the crossmember if anything needs rebuilding. So unless everything has already been rebuilt on the 'new' c.member, just swap the parts so you can inspect everything as you do the swap.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-11-2007 at 07:22 PM. |
07-11-2007, 09:22 PM | #5 |
Location: vacaville ca, because it as far from indy as i can be
every thing is lined up and ready to go
its only 18 bolts total to remove the existing cross and 2 tie rod ends you will need to jack the front up pretty high though. i did the complete swap and you only have to drill 2 holes, one on each side, everything else lines up. |
07-11-2007, 10:09 PM | #6 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-11-2007, 10:46 PM | #7 |
swap everything out and leave the xmember. I am about to do the same with my truck soon
07-12-2007, 10:22 PM | #8 |
I must be missing something here.... I'm doing the 8 lug to 5 lug swap myself(asked the same ??? a fiew weeks ago) and I was told I had to swap out the x-member because the 69 8 lug set up was different than the 87 5 lug I plan to change all the pieces-parts w/ new stuff, but for now , to just get the roling chassis going (to tub the rear and establish a ride height) I just unbolted the fiew bolts and the whole thing fell out. I have to drill out a fiew holes but the whole unit slid in.............................any Ideas ??
1969 chevy C-20 (soon to be shortened & Tubbed C-10) 1990 Astro AWD 3" Lift w/Laredo tires 10 spkr. 800w system and DVD player for the long trips (got it for free) and been trying very hard to "De Socker-Mom it ! |
07-13-2007, 04:53 AM | #9 | |
If you want 1/2 ton, swap as much as you can.
07-13-2007, 01:11 PM | #10 |
the a arms are different on the bottom of the 8lug stuff, longer. it would give you and insane camber issue.
07-13-2007, 05:11 PM | #11 |
....So I take it that I am on the right track....Reading the prev. Question made me think that I was headed in the wrong direction....Thanks Guys.
07-19-2007, 10:06 AM | #12 |
Set up for sale with new drop spindles.
07-19-2007, 12:09 PM | #13 |
07-19-2007, 03:14 PM | #14 |
Robbing parts from the blazer It was just sitting there looking so innocent so I said what the heck. The blazer is not going to be done anytime soon and it has brand new drilled and slotted rotors and new pads, I replaced the original lower balljoints and everything else was tight. I may keep the drop spindles but for what I will spend on tubular upper and lower controls for it and the big brake kit we were talking about I could afford to put vette suspension under it. I am going to rob the rearend also since it has new impala ss brakes on it, new gears and locker. I will probaly end up and mini tub it and run a 22x10 on the back of it. I decided I should just save my money and turn the blazer into what I really want instead of what I can afford right now so it will probably be 2009 before it is done and that is fine with me.
