07-11-2007, 10:18 PM | #1 |
47-55 weight?
What does a 3 window shortbed with a MII frontend weight? I`m guessing about 3500lbs? sound about right?
Anthony |
07-11-2007, 10:28 PM | #2 |
Re: 47-55 weight?
something like that. It isnt much.
07-11-2007, 10:43 PM | #3 |
Re: 47-55 weight?
The reason I ask is I`m still trying to buy this truck from this old man I know and I`m getting a great running 327 from another friend and I figured if the weight is close, it should run just as good in the old truck if I gear it the same. Thanks.
Anthony |
07-12-2007, 02:23 AM | #4 |
Re: 47-55 weight?
What BHP is the 327? What are your plans for the pick up?
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
07-13-2007, 12:02 AM | #5 |
Re: 47-55 weight?
Hey there, I've got a 55 1st. 5 window running a 283, with a 350 turbo and 12 bolt rearend. I had it weigted and it came to 3,220 lbs. If that any help to ya.
07-14-2007, 08:59 PM | #6 |
Re: 47-55 weight?
I don`t know the hp rating of the motor but it would probably run high to mid 13`s in my buddys chevelle. My plans are pretty much just to drive it but I want to burn up some tires sometimes too,lol. deabt54,yeah that does help alot. i plan to run a th350 and a 9" so the weights should be similar. Are you running the stock fronend or a MII set up?
Anthony |
07-14-2007, 11:55 PM | #7 |
Re: 47-55 weight?
Its stock with 5 lugs and drums. Getting ready to put a 89 corvette suspension up front. Got the cross member from Progessive Automotive. Should be fun LOL!!!!!
07-14-2007, 07:04 PM | #8 |
Re: 47-55 weight?
I would not have gussed that these trucks are that light, with all that real steel!!!!
07-15-2007, 10:13 PM | #9 |
Re: 47-55 weight?
