Old 07-14-2007, 02:33 PM   #1
mholmes
Tranny questions
I've got an '82 Chevy Scottsdale 4X4 with automatic transmission that I just did an engine swap in. I replaced the factory 305 with a new 350 that I got from JEGS. Engine swap was done with the help of 2 others that knew what they were doing. I replaced the distributor and carb with new ones also. My problem is now when I put it in D the transmission feels like it's not going past 3rd gear. Any thoughts or ideas on what might be wrong?
mholmes is offline   Reply With Quote
Old 07-14-2007, 05:58 PM   #2
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: Tranny questions
maybe a dumb question, but is it an OD tranny like 700R4? Cause, you know, if it's a Th350 there ain't no gear past 3rd. Another thing, OD trannies rely on the TV cable to tell them how much pressure to apply to the clutches and how long to keep gears before upshifting - too loose of a cable burns up yer tranny, too tight of a cable keeps gear real long and may prevent OD engaging. TV cable adjustment or at least check is necessary when the carb is replaced, so maybe there's yer problem?
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 07-14-2007, 07:54 PM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
agree with him
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
