Old 07-15-2007, 12:45 AM   #1
canadianc-10
vss on a 84 c10?
anyone know if a 84 gmc loaded 2wd has a vss? thot i seen a small box directlly behind instrument cluster, buts been so long since i last crawled under there and dont know if thats it. hooking up a nav unit.
canadianc-10 is offline   Reply With Quote
Old 07-15-2007, 02:35 PM   #2
Jonboy
Slots go on anything!
Re: vss on a 84 c10?
Yes, it should. The VSS buffer plugs in to the back of the speedometer head, and sends a signal to the ECM.
Jonboy is offline   Reply With Quote
Old 07-15-2007, 05:49 PM   #3
canadianc-10
ok cool thanx. found 3 wires coming out beside speedo cable going to a small bright yellow or green module. is that the vss?
Old 07-16-2007, 09:03 AM   #4
Jonboy
That is the buffer, that converts the light pulses to an electric signal.
Old 07-16-2007, 09:54 PM   #5
68Stepbed
68Stepbed's Avatar
What exactly is vss?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-16-2007, 10:17 PM   #6
canadianc-10
ok excuse me for being a little dense lol. the vss is inside cluster with the yellow black and pinkishblack wires to buffer? vss= vehicle speed sensor
