![]() Join Date: Sep 2005
Tachometer issues
I have a 1978 GMC truck with a V8 in it. I have a tachometer cluster that I have had for a while that I was going to put in this truck. I had not paid attention, but as I look closer it appears that this tach cluster may be for a four speed truck. I looked, and there is no PRNDL indicator on it. I think other than that the tach is correct for the truck. Can anyone tell me if this cluster is correct for 1978 and can I convert it for an automatic by putting the PRNDL indicator from my existing dash? The gauges and everything are in really good condition so I would like to use it if I can.
James |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Tachometer issues
you may be able to use the white piece from your guage cluster and set the guages and the rear circut board from this one into that.. its been a while since i did this but i think youre missing a piece from this to screw in your gearshift indicator from one to the other
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Dark Heart Motorsports
bevel it out... a dremel is an awesome thing to utilize
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
here's one out of an auto.
" Never look up a dead dogs butt." ![]() |
THE VILLIAGE IDIOT
thats the guage cluster im hoping to find..but im also thinking of going with after market gauges...looks like a nice cluster
honestly honey,,i have no idea how that truck got here. ![]() |
IF the Oil gauge is electric, you're 90% there. That speedo has only 1 indicator light at the bottom. Does your existing cluster have 2? And are there spots for 2 on the back of that tach cluster? Can you post a pic of the back of that cluster?
#7 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
If the oil pressure gauge is NOT mechanical (actual tube going to the engine block) it should be the '78-80 version. The picture you posted is NOT a 1978 cluster. It is a 73-75 cluster due to the fact it has an AMPS gauge on it
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Prong, well it looks like I am not 90% there. The oil gauge is NOT electric. My current speedo has two lights at the bottom, but the cluster in the picture appears to have a place for the second light. Maybe this is not the best place to start to add a tach to my truck. I will try to post a picture of the back of the cluster a little later. Just in general, however, are the tach's pretty much interchangable between a four speed and an automatic if you have the PRNDL piece? If you have a four speed can you just remove that piece? Thanks James
James |
Wide n'Low
![]() Join Date: Jan 2007
I am fairly certain that I have a spare cluster in good working order, I will check tonight. It came out of my 78 C/10 auto.
I will post one way or another tomorrow. Drew |
#10 | |
As I alluded to above, yes, ALL of them have 2 lights at the bottom. The one not in use on 2WD's is the 4WD light. They are interchangable, you either have the gear indicator or you don't.
