Old 07-15-2007, 02:46 PM   #1
wannabelow
oil leaking in cab
i have oil leaking in the cab right by the gas peddle and when you foot is on the gas id drips on your foot
its a 72
wannabelow is offline   Reply With Quote
Old 07-15-2007, 02:51 PM   #2
redhead69
fugedaboutit
redhead69's Avatar
Re: oil leaking in cab
Check your oil seder under dash or where your brake pedal rod goes thru the firewall/ master cylinder..
Currently truckless
redhead69 is offline   Reply With Quote
Old 07-15-2007, 02:55 PM   #3
cdowns
cdowns's Avatar
these have mechanical oil pressure gauges meaning theres a small diameter metal tube the carries oil from the bck driver side of the engine block thru the firewall to the oil pressure gauge// its leaking
Old 07-15-2007, 02:54 PM   #4
bad6772
Official Site Guitar Shredder
bad6772's Avatar
bad6772 is offline   Reply With Quote
Old 07-15-2007, 02:57 PM   #5
wannabelow
thanks guys
Old 07-15-2007, 10:33 PM   #6
70C10Toejam
Hellasick
70C10Toejam's Avatar
at least you didn't get enough of a leak to burn yer foot!!
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
