battery not charging
ok guys, I'm getting sick to my stomach trying to figure this truck out... I bought a new external regulator and didn't help, got alternator tested and was bad, but new on one, and still not chargin battery. I found some bad wires from the alternator to the regulator and have fixed that problem and tested with the multi-meter and are good from alternator to regulator and still not charging battery, only running 12.XX at the battery and at the postive on the alternator.
Guys what else could the problem be!! Need all the help!!!! what do I need to look for or test? thanks all knowledgeable ones! ![]()
1972 SWB Cheyenne |
Re: battery not charging
Check to see if you have a complete circuit between alt. large red wire and the battery + terminal. If not your fuse link is blown.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
I Have A Complete Circuit From The Alt. To Battery, Still Can't Figure It Out!
1972 SWB Cheyenne |
If the wires from the alt. to voltage reg. are right, then you have another bad alt. Check to see if you are getting voltage to the plug-in wires on alt. with switch on also.
Ever heard of Beech Island??
have you revved the engine up. my alternator kicks on once it hits 1500 or 2000 rpm after I crank it up.
![]() Join Date: Mar 2007
I just went through the same thing with my truck. I replaced the battery, alternator, and regulator. Turned out to be the horn relay.
![]() Join Date: Aug 2006
With the truck running, disconnect the pos. battery terminal. If the truck dies your system is not charging. If it stays running test the voltage from the pos. cable to the neg. terminal and the body ground. You should get between 13-14vdc. You could have a partial short or the battery itself could be dragging it down. Good luck.
thanks for all the help guys. it's nice to hear all opionions on this subject..
I will check out all the items your guys have listed. i have replaced the battery, alt, and regulator.. ![]() I might have to check the horn relay thanks again gentlemen.
1972 SWB Cheyenne Last edited by kawman10; 07-17-2007 at 12:46 PM. |
