Old 07-16-2007, 11:33 PM   #1
Idaho Bob
Blazer top glass thickness
Does anyone know the thickness of the glass in a single wall 72 Blazer top (I think it is either 3/16" or 1/4")?
Is the side glass the same thickness as the hatch glass?
Thank you for your help.
Idaho Bob is offline   Reply With Quote
Old 07-17-2007, 09:25 PM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Blazer top glass thickness
I have some orginal glass out in the storage shed. I went out and miked it;
it shows .215 thats right at 7/32". I am not a glass expert so I dont know if that is what "1/4" glass measures at, your glass shop should know that. It was the same for side and rear pieces.
Tom Vogel is offline   Reply With Quote
Old 07-17-2007, 10:46 PM   #3
Idaho Bob
Thank you very much. I, too, miked the glass and came up with .204 (close to the 7/32" that PPG told me it would have been originally). Replacing it with tempered glass gives me only 3/16" and 1/4" options. I will opt for the 3/16" plate to be tempered--a little sealant between the glass and the seal is better than having the seals fit poorly around the fiberglass, which is, I understand, what might happen with the thicker 1/4" glass.
Old 07-19-2007, 11:02 AM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Hey thanks for sharing that. I didnt realize thickness options were a problem. There was a guy at the Pleasanton Goodguys show last year that specialized in flat plate... custom cut for classics and hotrods; he had a large selection of tints (incorporated into the glass)too. Now if I can just find his info and card in all the reems of stuff Ive been colecting for this project.
Old 07-21-2007, 08:26 PM   #5
Idaho Bob
I spoke with PPG--they no longer make the top glass. PPG sold the blueprints to The Glass Man (classicflatglass.com) in California (530) 626-6923 who will cut them and send them out for tempering. PPG part numbers are DT1107 for the side windows and DT1108 for the hatch glass.
Old 08-08-2007, 12:26 AM   #6
Idaho Bob
Just to update--the correct thickness is 7/32 and is available tempered through classicflatglass.com.
Old 08-08-2007, 11:54 PM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Yep; thats the guy I was talking about. Now I dont have to keep scrounging to find his number.
