07-17-2007, 11:22 AM | #1 |
disc brakes and torsion bars
So I want to do the disc brake spindel swap. My question is : Is there any thing special on replacing the spindels on a torrsion barr set up ? I mean with coil springs you remove them prior to taking the spindels off, what needs to be done with thr torsion bar? Thanks.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 07-17-2007 at 11:43 AM. |
07-17-2007, 02:13 PM | #2 |
Re: disc brakes and torsion bars
Any one done the swap on 60-62 ? Any tips ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 07-17-2007 at 11:47 PM. |
07-17-2007, 11:48 PM | #3 |
help me 60-62 owners !!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
07-18-2007, 11:11 AM | #4 |
I wish I could Slepysal, but we performed a complete front crossmember swap spindle to spindle (86') to acquire the end result. Sorry!
I am sure some one will provide the information.
________________________ 62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
07-18-2007, 07:05 AM | #5 |
UCA63
I have a '61 GMC and was wondering the same thing???
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
07-18-2007, 11:25 AM | #6 |
I just looked at the LMC truck catalog, and it looks like you might be in a pinch. They have drop spindles for your truck, but it might be a good time to swap the front end to a later coil spring front. Easier to get parts, components are much cheaper, and you could put airbags in later if you want to.
07-18-2007, 11:37 AM | #7 |
1962 C-10
My '62 has the front suspension for a '73. Parts are a dime a dozen.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
07-27-2007, 05:53 AM | #8 |
Hi Sleepysal, I done a disc and drop spindle kit on my 60 panel and it was easy providing you use a BIG hammer to split the joints! I also put a small bottle jack under the bottom arm before i split the joint and it was useful to lift the arm up and into the new drop spindle afterwards. Hope this helps, Steve.
07-27-2007, 11:14 AM | #9 | |
