Old 07-17-2007, 03:21 PM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Help !!! Wheel lug Q????s
Ok heres tha deal
I have a 67 that the PO converted to 5-lug, but when he did he made it 5 x 4 3/4 instead of 5x5
So I want to change that, the rear is no big deal cuz I'll either swap rear ends or axles
But the front is where my questions come in
I found some sweet look'n 6-lug wheels today at a good price, so now I'm think'n bout go'n back to 6-lug
But I still want disc brakes, what do I need to do this
Please steer me in the direction I need to go, thanks Matt
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-17-2007, 03:35 PM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Help !!! Wheel lug Q????s
Can I just put these on my 73-87 spindles ???
http://www.classicperform.com/Store/...ruck/CP4R5.htm
Sinister
Killer
Old 07-17-2007, 04:09 PM   #3
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Good question.... 5 x 4 3/4 is a car bolt pattern as far as I now. I would think the spindles would be different and wouldn't except the new rotors That's just my thought
LOW DOUGH is offline   Reply With Quote
Old 07-17-2007, 04:10 PM   #4
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Well, HMMMMMMM do car spindls fit on these truck? I don't know
Old 07-17-2007, 07:19 PM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I dunno either, I just consider it a mutt
I'm gonna pull the A-arms off a parts 73-87 I have, so I'll know what everthin is
Sinister
Killer
Old 07-19-2007, 11:02 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Ok, new thought
Will 6-lug 73-87 rotors work on 73-87 5-lug spindles ???
Sinister
Killer
Old 07-20-2007, 09:49 AM   #7
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Originally Posted by Spray-Bomb View Post
Ok, new thought
No.... Because a 6 lug 73 -87 is a 4x4 truck with a solid front axle.
Old 07-20-2007, 08:24 AM   #8
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Need to know A.S.A.P.
Sinister
Killer
Old 07-20-2007, 10:11 AM   #9
poorboy
poorboy's Avatar
You can buy 6 lug rotors that will bolt onto the splindle.
poorboy is offline   Reply With Quote
Old 07-20-2007, 10:53 AM   #10
67ChevyRedneck
67ChevyRedneck's Avatar
ECE sells the rotors as well. $$$ but very good quality.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-20-2007, 10:54 AM   #11
71tahoe
71tahoe's Avatar
Is the back still 6 lug?
71tahoe is offline   Reply With Quote
Old 07-20-2007, 04:50 PM   #12
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
No, I'm swap'n it out to a 6-lug I have lay'n around
Ok, why not 3/4 ton rotors ???
And if those won't work, would you use ECE or CPP
Sinister
Killer
Old 07-20-2007, 07:29 PM   #13
poorboy
poorboy's Avatar
This could be similar to what's on your truck to get the 5x4 3/4 pattern.
http://www.classicperform.com/Store/...k/6062CBK5.htm
3/4 ton spindle kit is $619 for stock heigth.
http://www.classicperform.com/Store/...ck/6370SSK.htm
Old 07-20-2007, 07:30 PM   #14
poorboy
poorboy's Avatar
I think as far as the rotors go it's personal preference.
Old 07-20-2007, 09:06 PM   #15
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
The reason I wanna find out if some stock 6-lug rotors will fit , is so I can save a few bucks
If there aren't any that fit, it's ok cuz I'll just buy the $130 rotors from CPP
Sinister
Killer
Old 07-20-2007, 11:35 PM   #16
70C10Toejam
Hellasick
70C10Toejam's Avatar
to do off the shelf 6 lug rotors, you will have to do this:
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
using 88-92 LIGHT DUTY 3/4 ton.
otherwise, you will have to use ECE or CPP 6 lug rotors. I used an '85, with CPP rotors, no probs for me. woulda done the 3/4 ton one, if I knew about it at the time, just cause it is all -off the shelf-parts.
as for the initial part of the post, you can buy kits that use full-size car brake parts adapted to our trucks with brackets and wheel bearing adaptors, sounds like what the PO did.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 07-21-2007, 09:39 AM   #17
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My guess is that having a car bolt pattern says your spindles are sized wrong for truck-pattern rotors. That will make having the calipers in the right position a difficult guess. Truck rotors should be 12-inches in diameter. Car rotors may only be 10 or 11 inches. If that is the case, you can see why the caliper won't let the rotor be usable. Measure your current rotor to be sure that the rotor you buy will work on your spindles. You also need to know the O.D. of the spindle....hope you succeed in your task.
People take short cuts to save money, only to cause someone else to have to spend a bunch to fix it.
Member Nr. 2770
Old 07-21-2007, 09:51 AM   #18
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
70C10Toejam
The thread you directed me toward was a very good thread, but was for 88 up & thats not what I wanna do
ChevLoRay
As I said before, I'm gonna swap everything out to 73-87 front end parts (as that is what my parts truck is) So that I know what everything is
Sinister
Killer
Old 07-21-2007, 09:53 AM   #19
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I will be pulling a rotor off my parts truck, so I can take it down to my local parts store and see if a 73-87 or 88-98 6-lug rotor will intercahnge
I'll keep ya posted
Sinister
Killer
Old 07-21-2007, 03:33 PM   #20
TN70C10
im currently swapping mine to 5 lug 5x5 , looking for wheels i almost wish i was going 5x4.5 just for the wheel selection, im picky about wheels and havnt found any 5x5 that i like for under $2000, can find all kind of 4.5's though.
TN70C10 is offline   Reply With Quote
