Yellow truck club
Rad hose question.......
I'm running a SBC with stock rad top center inlet and bottom passenger outlet. PO has the generic ribbed hoses and want to put some that look more factory. Anyone have suggestions on what will work? Local parts guys just offer the ribbed at different lengths....
Brian ... ![]()
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
tiggerstoy
Re: Rad hose question.......
you can perchace high heat, presure hose from any hydraulic fab shop for a good price.
I took a template ( welding rod) of the bend I wanted to the parts house and went thru the rack of hoses until I found one that was close, shortened it a bit, and it looks like it came that way!!!
I did what solidaxel said on a '47 panel I did. Since your doing a 55-59 how about using the stock hose for the small block that was offered? I'm thinking of doing that myself.
Steve |
