Old 07-19-2007, 10:36 PM   #1
fercho71
fercho71's Avatar
how to take off the dash panel ?
well i got my new dash panel and started to take off the old one i all ready dismount the ignition switch, the wiper switch etc. but when i intended to dismount the light switch i just couldn't can anyone please give me a tip how to take it off?
1966 chevy c-20 truck " La Chata " under construccion
fercho71 is offline   Reply With Quote
Old 07-19-2007, 11:33 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: how to take off the dash panel ?
The shaft pulls out of the headlight switch. On the switch body (behind the dash) there is a button that needs to be pushed in, which releases the shaft allowing you to pull the shaft and knob out. Then you can unscrew the bezel nut.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-19-2007, 11:41 PM   #3
fercho71
fercho71's Avatar
thanks Fred i will tried that tomorrow
Old 07-22-2007, 11:58 PM   #4
Woogeroo
ya pull the light switch knob all the way out, to where it is with the lights on.
with one hand, hold the light switch knob, with your other, reach under and push in that button, and hold the button all the way down... you'll feel a click or something.
Then, with your other hand pull out the knob. You won't have to pull hard on it, just give it a firm, but gentle pull.
To reinstall, you put the knob back into the switch, press in that button and push in the knob.
good luck...
it was kinda funky for me the first time I tried it also.
-W
Woogeroo is offline   Reply With Quote
Old 07-22-2007, 12:20 AM   #5
fercho71
fercho71's Avatar
Re:still the problem on how to take off the dash panel ?
hey guys i found the button behind of the switch i already push but the shaft won come out and i pulled any tips
