Old 07-20-2007, 06:08 AM   #1
97guns
what type & WT oil for my '71 350?
i have some castrol syntec 5w/50 thats rated sj in my garage and was wondering if i should use it for an oil change. i have been reccomended shell rotella in another forum. just wondering what i should run.
'71 LWB 350/350 banana yellow
'02 VW GTI turbo 14 sec. 1/4 mile
97guns is offline   Reply With Quote
Old 07-20-2007, 09:16 AM   #2
cooters
Re: what type & WT oil for my '71 350?
castrol is great but dont run synthetic in a high miler motor as it will go through oil. 10-30 Castrol is my choice
cooters is offline   Reply With Quote
Old 07-20-2007, 11:09 AM   #3
manimal
manimal's Avatar
Shell Rotella T 15w40 and a wix 51061 filter.
-Lance
Castrol does not have the zinc.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-20-2007, 11:34 AM   #4
Either will work, but like was said a high mileage motor may have some leakage issues if you start running the synthetic. Shell Rotella for diesel engines (use in gas or diesel) is about the best conventional oil on the market right now.
Old 07-20-2007, 01:09 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
The studies have put down that the Shell Rotell has the additives that a lot of other brands have removed from their oils. These additives are needed for the older motors to provide the proper lubrication for the conventional design bearings and valves. The new grades and the synthetics are a "TRI" molecule based oil and it is not carrying the basics that the older Dinosaur olis did.
Old 07-20-2007, 01:47 PM   #6
Jayss109
Active Member
Jayss109's Avatar
Even the new Rotella is eliminating all the good stuff (zinc etc). All the new emissions stuff for diesels is making the oil manufac. remove it. GM eos additive is a good choice as well
Cadillac Powered
Jayss109 is offline   Reply With Quote
Old 07-20-2007, 02:15 PM   #7
Spanky_Pete
Too many trucks? Nah...
Spanky_Pete's Avatar
I have always run Castrol 10w30 in my small block chevys. I'll have to check into the Shell stuff.
Spanky_Pete is offline   Reply With Quote
