LSX engine mounts
Who makes the best ones? I want to slide the motor back an inch or two...Who builds those that slide the motor back? Thanks Guys for the help
06 Crew Cab GMC[/B] on 22's 07 Duramax 4x4 Lifted Maxed Out! 1972 2WD K5. 89k miles. Soon to be bagged, LS1 and bad! 1967 Short and Wide. Soon to be an LS1 and bagged |
Questionable
Re: LSX engine mounts
Go with the plates, then. Don't go with the ECE mounts, they will put the engine a decent bit forward in the engine bay. There are any number of places that sell the plates, including S&P. All of em are about the same damned thing.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Always wrenching!!
with the plates can you use the orignal frame mounts? just bolt the plates to the motor then the mount to that? using a 4l60e will the trans fit the cross member or will it need to be modded? are th350 and 4l60e yokes the same spline? thanks in advance!!!
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
When I did mine I used the Advanced Adapters plates and then replaced the stock perches with the tubular type-got mine from Brothers, but i've seen them from others also. They adapt to a passenger car type mount where the Motor mount bolt runs longitudnialy (sp?)- front to back- instead of coming in from the back of the stock perch. I then used some poly mounts from Energy. I did have to drill new mounting holes about 3/4-1" back from the stock location because the pan was hitting the x-member (LS1 out of a 2000 camaro). Theres a pic of the L&R below if that helps... For the tranny I was able to use the stock x-member- just redrilled holes in the frame a little farther back and used another poly mount from Energy. I dont have any pic's but I think it was an inch or so farther back. The stock shift linkage looked like it would have worked also, but it was worn pretty bad so I replaced it w/ some Lokar linkage. Hope this helps... Good luck!
'08 VW GTI- daily driver '74 CJ5 in pieces (4-bolt sb406/700R4 & 3/4ton running gear) '70 C10 W/ LS1 & 4L60E |
Questionable
That covers most of it. To answer your spline questions read this: http://67-72chevytrucks.com/vboard/s...=700r4+splines
You can use the stock automatic tranny crossmember (NOT the 3spd one!!) and it is nearly a direct bolt up. You may need to drill new holes in the stock mount to bolt up, depending on which mount you use (or maybe for all mounts). I suggest going aftermarket for the crossmember. If I had my choice to do it again, I would use CPP's tubular tranny crossmember, it is much easier to install than ECE's.
Always wrenching!!
thanks for the info!!! im trying to do my cheap. i dont have a prob doing a lil fab. would the stock mounts work with the block side adapter plate? or do u need to change to the tubular style? the cross member ill just move and drill as need be. i just want to drop the 5.3/4l60 in without havin to change drivelines. i spent all my money on my camaro haha!!! so cheap is the plan for this!
#7 | |
Digging up an old post, but I am wondering the same thing. Although I think he meant stock SBC frame engine towers. Anyone have any idea if the tubular pieces are required with the adapter plates? Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
Always wrenching!!
i ended up moding the passenger side mount to allow the stock exhaust manifold to clear. I am having to change them out to the tubular frame side mounts now since im adding a/c.......
Questionable
If you want to go cheap, check this post:
http://www.ls1tech.com/forums/showpo...46&postcount=5 See the third links for 68fleetsidec20's budget buildup thread using stock gas tank. I'm tellin' ya, check out all of the links, you'll get a LOT of ideas about what other people are using and you can price out from there ![]()
