Old 07-22-2007, 06:02 PM   #1
Biff
GM Gypsy
Biff's Avatar
Power Steering Box Leak Question
The power steering gear box in my 72 4x4 leaks bad. It seems to be leaking right where the steering column goes into the box. Does anyone know what I might need or if there is a seal kit available? Thanks. (I posted a WTB for a power steering box in the classified section and " hgs_notes" replied that I can get a rebuild seal kit.) I am not sure what I need though.
1972 Custom 10 Deluxe LWB 4x4
2003 Power Wheels Barbie Jeep (2 daughters ya know)
2004 Silverado Crew Cab Z71- Sold
Here's to your coffin...
May it be built of 100 year old oaks which I will plant tomorrow...
Biff is offline   Reply With Quote
Old 07-22-2007, 06:22 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Power Steering Box Leak Question
I would leave this project up to the pros. If a gear box is set up with the wrong amount of backlash it could lock up in the middle of a corner.
Look around for a company that can rebuild your unit.
We have a place called steer & gear in Columbus that can do it.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 07-22-2007, 06:50 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Look around for a company that can rebuild your unit....
I agree. I tried to replace the seal on one of mine and it was not the easiest thing to do if you've never done it. It would lock up on me when turning the steering wheel.
Wound up having a mechanic friend that worked on them all the time fix it for me. In retrospect, I should have gone to him first....
68gmsee is offline   Reply With Quote
Old 07-22-2007, 08:36 PM   #4
Biff
GM Gypsy
Biff's Avatar
Thanks for the info guys. That is what I will do then.
