09-22-2002, 11:50 PM | #1 |
rochester carb id number
when i bought my 67 3/4 4wd it had a rochester 4bbl on the 327. i would like to rebuild it but i can not find the id number. most of the time it is written on the drivers side of the carb right? where else might it be?
67 k-20 w/327 and a 3speed and 4.57 rear with 17 inch split rims and 9 inch wide rubber(is my current project) 73 blazer 6 inch all spring lift 350/350 with crappy 3.08 gears and 35 inch bfg tires. just put out 135 hp to the wheels on the dyno. 54 chevy delray .060 over 250 i-6 which was taken from my first truck(68 gmc). it is next in line for a rebuild |
09-23-2002, 09:43 AM | #2 |
67-72 Addict!
I think the 4 barrels are on the passenger side.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-23-2002, 12:17 PM | #3 |
The quadrajets I have owned were all on the drivers side.
Here are a couple of sites to check out. The first has a pic of where the numbers are: http://meltingpot.fortunecity.com/th.../rochcode.html http://www.carbs.net/quadnumber.htm
Rod Childers '71 C10 Stepside |
09-23-2002, 02:43 PM | #4 |
My quadrajet number is on the driver's side. Also, it is a rochester design that was built by Carter. On the drivers side it is stamped with the words "manufactured for GMC by Carter".
1972 C-10 LWB, 400/350, 2WD 1972 C-20 Custom Camper, 350/350, 4WD (Converted) |
