07-25-2007, 09:44 AM | #1 |
The Peacemaker
Vacuum Line Questions
Just need some help with a good placement of the vacuum fitting, and what lines go where. I have a line from the Tranny that I know is a vacuum line and the dizzy, and the carb I believe, but where do they all go? I'm not even sure the tranny one was hooked up with my sbc in the blazer.
1978 Chevy 2wd Stepside aka "Audrey" Cordova brown with mandarin guts 79k original miles & being restored 1979 Chevy 2wd Short Wide aka "Emma-Jayne" Cordova brown with mandarin guts 2019 Chevy Tahoe LT Previous rides: -2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB. |
07-25-2007, 10:48 AM | #2 |
Re: Vacuum Line Questions
vacum from tranny goes off manifold back by your dizzy off that small 90 fitting.it should have been hooked up or it wouldn't shift.the one from dizzy vacum pot goes to lower left port on your edelbrock.big one on back of carb to pcv in valve cover.then you need manifold to brake booster line.i'm not familar with what your setup is for the other port on your t fitting is.
" Never look up a dead dogs butt." |
07-26-2007, 01:12 AM | #3 |
The Peacemaker
From your description so far... I should place the fitting probably in the right side like in the picture and the tranny line and brake booster line will go to that. Then I have the pcv valve go to the front of my edelbrock carb and dizzy canister line to the lower left port on the front of my carb...is that right? And you have no clue what the 3rd port or my fitting is for? Thanks boat, this is really helping my out...I might actually finish the thing if I can get my radiator mounted right.
07-26-2007, 11:19 AM | #4 |
hello,,on my carb'd 5.7 tranny line goes to intake,behind carb,,dizzy goes to left front carb,my pvc is hooked up on front of carb,brake is hooked up to intake,everything else on mine is plugged off..
07-26-2007, 01:20 PM | #5 |
thats like mine..........better said.than i could explain.only i have hydroboost brakes no vacum.you should have a bigger line from your brake booster than your other's.you'll need a 1/2 dia. 90 off back off manifold dedicated for that it's not the third hookup on your little t.i think it's 1/2 inch they'll know at auto parts store.
" Never look up a dead dogs butt." Last edited by boatpuller; 07-26-2007 at 09:03 PM. |
