Old 07-25-2007, 10:19 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
A/C compressor seal?
OK, so I got my A/C working in my 72 GMC truck, with the original A6 compressor. I converted the system over to the R 134 with a new POA valve. The guy that did the work told me it was leaking though, in the back of the compressor where the big cover plate goes on. Is Anyone aware of a gasket or seal the can be replaced there?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 07-25-2007, 11:41 PM   #2
Ridgeback
Re: A/C compressor seal?
Under that plate in the rear of the compressor are two o-rings, but often the plate itself is warped or the tubing is cracked at the weld.
Ridgeback is offline   Reply With Quote
Old 07-26-2007, 03:08 PM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Are you talking about the aluminum block that the lines bolt to the compressor? Because I am talking about the big round plate that bolts to the round compressor housing. There are 4 studs that are spot welded to the round comp. housing. Should I take the back off the comp. and look for the 2 o rings?
Old 07-27-2007, 12:13 AM   #4
Ridgeback
I was talking about the aluminum connector block. However, there is also a large o-ring that seals the compressor rear head to the compressor shell which is the connection you are talking about.
Old 07-27-2007, 02:54 PM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Yep, that's what I'm referring to. Any ideas where to get one of those seals?
Old 07-27-2007, 03:03 PM   #6
killer71
killer71's Avatar
have you tried lmc?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 07-27-2007, 05:43 PM   #7
john
member #16
john's Avatar
It has an o ring on the rear cover. I would see if NAPA has a kit, or take it apart and match it from a o ring supplier. Heres a soso diagram of the A-6 comp. this place also has some A-6 kits but it didn't specify which o rings.
http://www.ackits.com/diagrams/GM.pdf
john is offline   Reply With Quote
Old 07-27-2007, 10:42 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
here is a link for a newer application.
http://bernardembden.com/xjs/comseal/index.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-29-2007, 11:54 AM   #9
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
John, thats what I'm looking for. Thanks! LMC doesn't list any internal compressor seals. I checked at the local Ace Radiator and can probably get an internal seal kit from them. It would be #14 in the diagram, I think. My A/C guy had it blowing *43. That's not bad, I guess. Thanks guys!!
Old 07-30-2007, 09:52 PM   #10
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Got it!! From the local Ace Radiator. Part # MT2117. The kit came with interior compressor seals, about 5 of them. Cost was $9. Now to get it installed.
