07-26-2007, 03:39 PM | #1 |
Member #1049
Small block AC Brackets
For Sale...
6 out of the 7 brackets for a short water pump AC setup.. Missing the horseshoe bracket that bolts to the intake manifold. Media blasted and painted with Rustoleum Semi gloss black. $120 shipped Paypal preferred Last edited by Livrat; 07-26-2007 at 03:40 PM. |
07-27-2007, 11:16 AM | #2 |
Member #1049
Re: Small block AC Brackets
ttt... New price $100 shipped
07-29-2007, 01:50 AM | #3 |
Hand Crafted C-10
ttt to you LivRat----
...for $100, thats less than $17 a pop... blasted and painted plus they're factory parts. Awsome!!! that's a great deal! Good Luck on your sale... |
07-29-2007, 08:43 PM | #4 |
would you do $75.00 shipped to 24281?
i have 67/72 chevy truck parts f/s. |
07-29-2007, 08:48 PM | #5 |
is the one in the middle far left the corect bracket ? it looks a little drifferent than my pic. in the lmc book.
07-29-2007, 09:55 PM | #6 |
Member #1049
billsbowtie.. Yes I would take $75 shipped to you..
I do believe the adjuster bracket you are asking about is correct for a small block with the stamped steel upper bracket that also had the smog pump option.. but not correct for the cast iron "horseshoe" bracket.. but can not confirm as I do not have any others to compare it to.. (it is not flat and does have two small angled bends) Does anyone else have any info?? |
07-29-2007, 10:17 PM | #7 |
livrat is this the bracket you are missing?
07-29-2007, 10:46 PM | #8 |
Member #1049
Yes that is the bracket that I do not have..
I do have the long stamped steel one that also is the lower mount for a smog pump which goes in the same position on the intake manifold and runs forward to the water pump Here is a picture of the adjuster bracket in question that is on my Burb. I can not confirm if it is correct either. It also is different that the one in the LMC catolog Last edited by Livrat; 07-29-2007 at 10:47 PM. |
07-29-2007, 10:58 PM | #9 |
Member #1049
Oopss.... I just realized after digging through my Burb pictures I do not have the front upper adjuster bracket on it.. and may need the one in the set I have offered for sale.. if you want the set for $75 I will honor it and go find another one... but if you pass I will pull the ad.
07-30-2007, 11:48 AM | #10 |
livrat you can keep the brackets it would cost quite a bit to buy just the one you need. i mostly needed the one that i ask about from intake to back of compresser. if you want you can pm me a price for the ones you don't need .i have 2 or 3 sets started . thanks bill
07-31-2007, 01:25 AM | #11 |
Member #1049
Thanks Bill,
PM sent |
