07-27-2007, 08:22 AM | #1 |
window trim
just got my new window trim from lmc. is there any tips or tools that will help with this. It looks like they just pop out in pop in with metal tabs. I just dont want to mess up anything putting my ride in a show tomorrow and this little thong will help set it off. Thanks for any help. It is the trim with the felt.
07-27-2007, 09:09 AM | #2 |
Re: window trim
sorry, i need to do spell check it is a little thing not a little thong. I must have my mind on something else. lol
07-27-2007, 09:29 AM | #3 |
Re: window trim
sorry they are called door window seals, if that helps.
07-27-2007, 11:19 AM | #4 | ||
Re: window trim
I saw another post that someone recommended gripping with pliers and pulling real hard on the old ones. New ones should securely clip in. I will be doing this in a couple of weeks. Maybe. Last edited by 71tahoe; 07-27-2007 at 11:21 AM. Reason: incomplete |
07-28-2007, 10:33 PM | #5 | |
Re: window trim
I assume your talking about the front and rear window s/s trim. You will have to remove the glass first, I would recommend a glass shop. esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
07-29-2007, 09:26 AM | #6 |
Re: window trim
I think ESLL is right. I was thinking window meant side window. I took the front trim out by cutting the windshield gasket. Someone else got half the back trim and I just peeled the whole glass, gasket and bottom trim out of the opening. It was still a little tough getting the last piece of trim out of the gasket without bending it to pieces. Unless your gaskets are fairly new, It will be pretty difficult getting new trim in there. You should spend about $70 and get new ones for the trim install. You didn't say, but if you didn't have trim before, you will need them anyway.
07-29-2007, 02:23 PM | #7 |
Re: window trim
If you are putting in the trim around the front or rear windshield, the rubber goes onthe glass first, then the trim goes in the rubber, then you putthe whloe ting in the truck. Also be aware that the rubber gasket must match the year of the trim, 67-70 is different than 71-72, has to do with the depth of the groove.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
07-30-2007, 09:56 AM | #8 |
Re: window trim
Put my truck in its first show on Saturday, It got second out of 15 trucks that were in it. A 1942 ford that was custumized got first, I might have gotten first if i had the bed wood redone, but happy for second.
